Re: Full exhaust and springs relocated?
[Re: 4404dart]
#926166
02/12/11 01:08 PM
02/12/11 01:08 PM
RapidRobert
I bought a 65 dart roller w the (super stock) springs relocated into the subframes w (I'm assuming) the MP square boxed deal w the angle cut on one end and the rear shackles welded on/hanging from the rear subframes and there will be no room for a stock width tank and the PO did not mini tub it at the same time so the gain was not that much and I'm going to put the springs back to normal so I can get a stock tank in there & be able to run tailpipes along side it
[Re: 4404dart]
#926167
02/12/11 06:34 PM
02/12/11 06:34 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
my B body has exhaust to rear, 345 wide tyres & most the remaining space taken up wit suspension... BIG job!
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: 4404dart]
#926169
02/12/11 11:25 PM
02/12/11 11:25 PM
Keith Black®
QLD Australia
we had to do major work to get the exhaust over the rear axle. 3.5in pipes required we fabricate a whole new raised hump over the rear axle & into the boot floor. Pipes were too large to run in the original location with my combo [which is a street car] I really need 4 mufflers to keep it as quiet as possible [which will still be noisy]. Pipe routing has a few twists (all mandrel bends) the use of V-Clamps for easy section disassembly.
