Re: Bronze bushing for distributor........
[Re: maximum entropy]
#925634
02/21/11 02:19 PM
02/21/11 02:19 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
well, thank a lot, guys. now i'm paranoid. i've installed hundreds of these things, and never had a problem with clearance or spinning. i use an unworn driveshaft to drive the bushing in, and then spin it until it spins freely. hundreds (i'm old). i knew of the tool, never never knew anyone who had it, so i always made do with what i have. i never did ream or cut the bushing. maybe that's why i've gotten away with it?
No you sized the bushing , maybe no the proper way , but driving it in wit han old shaft and spinning it till you could get the shaft out sized it, though you were lucky they didn't spin in the block i guess ?
I have thought about cutting a notch in an old shaft to make a sizing tool , similar to what some do with an old cam to size bearing after installed in a block .
