Re: Bronze bushing for distributor........
[Re: Challenger 1]
#925611
02/14/11 04:48 PM
02/14/11 04:48 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
I figured it out on my own, like 20 years ago when I was 20 or 30.
So are you 40 or 50?
[Re: Fury Fan]
#925613
02/14/11 04:49 PM
02/14/11 04:49 PM
Challenger 1
Cincinnati, Ohio
I'm not saying, sucks to get old. But I'm not old
[Re: RapidRobert]
#925614
02/14/11 10:44 PM
02/14/11 10:44 PM
Posts: 7,664 IN
ahy
IN
Anyone see a prob w epoxying the OD of the bushing b 4 you drive it in, more security
If the bushing and block were completly oil free it would really stick... then you'd need the tool to pull it out or a big punch from inside the disassembled engine.
[Re: Challenger 1]
#925615
02/15/11 06:05 PM
02/15/11 06:05 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Like I said earlier, some aftermarket bushings like the Pioneer don't need sizing but fit the block looser. Anybody that's using other than the factory tool to size the bushing needs to be aware (stand by for ruffled feathers) that there's a difference between doing it wrong and getting away with and doing it right; bushings that have spun in the block attest to that.
[Re: dustergirl340]
#925616
02/16/11 12:24 AM
02/16/11 12:24 AM
Posts: 543 Indiana, Just Off I-70
BradD
I only use the Miller tool! The first bushing I ever installed in one of my 340's was without the tool and the dizzy shaft was too tight. The only bushings I've used are the Mopar brand. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: John_Kunkel]
#925618
02/16/11 09:49 AM
02/16/11 09:49 AM
Challenger 1
Cincinnati, Ohio
I don't have any feathers, but I hear you and believe you.
[Re: Challenger 1]
#925619
02/16/11 10:51 AM
02/16/11 10:51 AM
Posts: 12,013 Finally a HUSKER again
Moparnut426
We just replaced the bronze bushing that goes into the engine block (small block Mopar) for the distributor, what size does it need to be reamed out to? The distributor shaft is .490 in diameter, I'm assuming a 1/2" would be fine? What do you think? Thanks
Hi, You want it tighter than .010" I just checked mine here that has been run and I have maybe .003" I'd be looking for .015-.003 on the side cleance.
I pressed the gear off this oil pump shaft and have used it when I drove a new bushing in. Stick the shaft in the new bushing and drive it in with a deep socket and extension. Then use a old screw driver chucked in a drill and spin it up. I do use a washer under it, just didn't have one handy for the picture.
So I would advise trying a stock shaft to ream it because it has a real nice taper built into it.
Mine is similar to yours, but I took and made a small spiraled groove in mine so when I spin it in the new bushing it gets nice lube all the way through it and wont gall. I had one galling up pretty badly when I didnt have the spiral groove, I might have been turning it too fast to though, Either way I have been using this for years. Better than the mopar tool whick I have also.
Kasey
[Re: 68red440]
#925621
02/17/11 05:22 PM
02/17/11 05:22 PM
Posts: 1,756 London, England
Gavin
London, England
OK, help me out here, I've never installed one of these but will need to and have read the debate every time this is posted.
Am I correct in understanding that the factory tool pushes the bushing in to place, then somehow as you withdraw the tool actually slightly expands the bushing thus both firmly lodging it in place (so it won't spin in the block) and simultaneously correctly sizing the inner diameter (so the shaft spins freely)???
If I'm correct then any method of installing needs to achieve those two objectives right? So if the bushing is just driven in and then reamed to size, why isn't there a problem with it spinning in the block? Either there should be enough interference to hold it tight, guaranteed, (in which case why the factory method?), or it risks spinning?
Or, as was suggested, are the (some?) aftermarket bushings differently sized somehow. Genuine question, just trying to figure this out, thanks.
[Re: Gavin]
#925622
02/17/11 06:05 PM
02/17/11 06:05 PM
John_Kunkel
Rio Linda, CA
Yes on all of the above. Even without burnishing, the bushing fits pretty tight in the block but tighter is better.
[Re: feets]
#925624
02/17/11 07:37 PM
02/17/11 07:37 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I'm dealing with this right now too, and not in a good way! My one piece gear/oil pump drive went in smoothly right until it got completely inside the block, when it started to get snug. This is on a fresh long block I bought. I could spin it with needle nose pliers but I couldn't get a good grip to pull it out. I figured it maybe had some carbon on it and it would get past the tight spot so I GENTLY tapped it down. No dice- still snug. Now I just want to get it out without removing the pan (full of fresh oil and zddp) and pump. Did I mention this is a new motor freshly installed ready to fire minus the distributor? I have magnet wire around so I'm thinking about making a strong electromagnet to grab it and either a slap hammer or right angle on the top to pop it out. I'm thinking that something like a pilot bearing puller would be too big of a diameter to grab the hole with the distributor slot in it? If I can't get it out that way it might be easier to pull the intake and get it that way I guess? Once it's out I'm sure a light polish will get it spinning freely. Don't be like me! rdr
[Re: Gavin]
#925625
02/17/11 11:55 PM
02/17/11 11:55 PM
Posts: 329 Cincinnati, OH
68red440
Cincinnati, OH
I pulled out my '68 manual: For all V8's, the (original Mopar) bushings were a press fit of .0005-.0040 into the block. The bushing hole should be .4865-.4880 which will give you a clearance of .0007-.0027. "Installation: (1) Slide a new bushing over burnishing end of Tool C-3053 and insert tool bushing into the bore. (2) Drive bushing and tool into position using a hammer. (3) As the burnisher is pulled through the bushing by tightening remover nut, the bushing is expanded tight in the block and burnished to correct size. DO NOT REAM THIS BUSHING." (says in bold print)
In the illustration, it shows the groove on the head of the bushing to be vertical. That allows oil to be directed down into the bushing.
Keep in mind that these instructions were used for engines that were designed to run 100,000 miles. Our hobby engines never last that long so using less precise methods might have worked fine for a lot of people. For piece of mind, I would find someone with the Miller tool and use it, or buy an aftermarket bushing that doesn't need burnishing. Either way, I would measure the bushing, the tool (if used), and the gear shaft diameter so you know what your clearance will be.
[Re: 68red440]
#925626
02/18/11 12:19 AM
02/18/11 12:19 AM
RapidRobert
My next one I'm gonna get the largest OD one (MP?) I can find/freeze it overnight/epoxy it in all to get the bushing anchored SOLID & get that squared away then work on getting the right clearance on the ID/intershaft. I'd want it tight & might add a very thin slit lengthwise in the bushing ID for some oiling
[Re: radar]
#925627
02/18/11 03:28 AM
02/18/11 03:28 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
Don't be like me!
rdr
A large screwdriver inserted in the slot turing counter clockwise will generally remove most stubborn drives..
[Re: radar]
#925628
02/18/11 11:07 AM
02/18/11 11:07 AM
Fury Fan
Indiana
I can't imagine an electromagnet being strong enough.
I would recomment removing the intake to get more room. Get an appropriately-sized piece of box tubing and cut a U-shaped slot thru one side so that the tubing will slide around the gear. On the other side of the boxtube, weld a nut or somehow make it so that your slide hammer will attach to it. Pop it out.
[Re: buildanother]
#925630
02/18/11 04:27 PM
02/18/11 04:27 PM
Posts: 5,080 organ
maximum entropy
organ
well, thank a lot, guys. now i'm paranoid. i've installed hundreds of these things, and never had a problem with clearance or spinning. i use an unworn driveshaft to drive the bushing in, and then spin it until it spins freely. hundreds (i'm old). i knew of the tool, never never knew anyone who had it, so i always made do with what i have. i never did ream or cut the bushing. maybe that's why i've gotten away with it?
