ID'ing lock-up 727 #924935
02/09/11 09:17 PM
02/09/11 09:17 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Yes, I know this has been done to death, and I do know how to ID a lockup IF the tranny is out of the vehicle, but is there any way to tell with the trans still in the vehicle? It's not driveable yet, so I can't take it out to "feel" it.
Re: ID'ing lock-up 727 [Re: tt76400] #924936
02/09/11 09:49 PM
02/09/11 09:49 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
The part number on the pan rail.
Re: ID'ing lock-up 727 [Re: 52savoy] #924937
02/09/11 10:17 PM
02/09/11 10:17 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
That I can get, where can I find a list of lock-up/non lock-up part#'s?
Thanks for the info!
Re: ID'ing lock-up 727 [Re: tt76400] #924938
02/10/11 12:41 AM
02/10/11 12:41 AM
PORT ALBERNI B.C. CANADA
71DemonRON Offline
71DemonRON  Offline
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: ID'ing lock-up 727 [Re: 71DemonRON] #924939
02/10/11 01:11 AM
02/10/11 01:11 AM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
thanks!!
Re: ID'ing lock-up 727 [Re: tt76400] #924940
02/10/11 01:19 AM
02/10/11 01:19 AM
On a 904 on the tail housing about halfway back on the side on iirc the dr side there is a 2 digit # ie "77" which if it is past the year of the changeover to LU's then that'd confirm it. Not sure if 727's have this cast # (I'm a 904 guy) but it'd b an easy check/fast way to confirm/deny
Re: ID'ing lock-up 727 [Re: RapidRobert] #924941
02/10/11 02:33 AM
02/10/11 02:33 AM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
Engine and trans are out of an early 80's truck or van, from which I understand, may or may not have the lock up trans. I know my '78 Fury 318 2bbl/904 was a lock up, but my '84 W-150 was not as it was a "heavier duty" vehicle, I just didn't know if there was any external identifying marks.
BTW, the link to that trans # id sight doesn't work
Re: ID'ing lock-up 727 [Re: tt76400] #924942
02/10/11 05:39 PM
02/10/11 05:39 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Link worked for me, it opens up to a PDF, so you might have to click in a GUI for open vs save vs cancel, and then it takes a few secs to load.
Re: ID'ing lock-up 727 [Re: 71DemonRON] #924943
02/10/11 08:18 PM
02/10/11 08:18 PM
Iowa
tt76400 Offline OP
tt76400  Offline OP
Iowa
ok, got it to work, thanks to all! Now I just have to crawl under the truck in the snow and get my #'s!
