Page 1 of 3 1 2 3
stealth head users please step inside #924827
02/09/11 08:01 PM
02/09/11 08:01 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
theres probably going to be a lot of bashing and trashing here asking about the 440 source stealth heads. im potentially in the market for some avg. guy alum heads and its 1000.00 for the stealths or 1500.00 for the eddys. id be changing springs, retainers,locks, checking valve job etc with ETHIER heads. whos got the stealths and whats to know about them? any tricks? the straight plugs help my pistons and headers... lookin better than the eddys at this point.....!!
74 dart sport 440 www.Csucarbs.com
Re: stealth head users please step inside [Re: shoebox] #924828
02/09/11 08:18 PM
02/09/11 08:18 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
My Dad runs them....loves them.....had to clearance for the pushrods.....changed to better retainers. Other than that....he runs 11.30's all day long with them....on pump gas.
Re: stealth head users please step inside [Re: Chassisman] #924829
02/09/11 09:11 PM
02/09/11 09:11 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
cool nice car BTW
Re: stealth head users please step inside [Re: shoebox] #924830
02/09/11 09:15 PM
02/09/11 09:15 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
I run them on my 470 stroker. I got a set of the first run of them. I welded up the chambers to run the gaskets I wanted and then ported them. I had my machinist give the a 3 angle valve job, narrow the seats and shave them .075.
I had to change the retainers and locks after running them for a while.
It runs 6.40s in the 1/8th. I v'e been happy with them.
Re: stealth head users please step inside [Re: shoebox] #924831
02/09/11 09:18 PM
02/09/11 09:18 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i've run mine for about 18-24 months.
running supplied locks/retainers springs after checking.i use a purple 509 cam.
machined to 78cc chamber and pocket ported.
i also had to clearance for 3/8 smith brothers pushrods
i used cometic gaskets from Don Gould
work great daily driven and regularly raced on pump gas
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: stealth head users please step inside [Re: tex013] #924832
02/09/11 09:22 PM
02/09/11 09:22 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Tex
I wouldn't get to upset about it. I had to clearence my Eddy heads for the 3/8's pushrods.
Re: stealth head users please step inside [Re: WILD BILL] #924833
02/09/11 09:25 PM
02/09/11 09:25 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i swapped from iron 906's-no worries.didn't find out till heads were on motor was in car grrr.
lots of masking off
Tex
New best MPH 130.32
Re: stealth head users please step inside [Re: tex013] #924834
02/09/11 09:52 PM
02/09/11 09:52 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
lots of masking off
Tex
I did the same thing!
Re: stealth head users please step inside [Re: Thor500] #924835
02/09/11 10:17 PM
02/09/11 10:17 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I'm running Stealth heads on my 512. I changed the springs, etc., to match my solid roller cam. They were milled to bring my compression up, and gasket matched. Other than that they're OOTB. I've run a best of 10.51 @ 127 with them.
Re: stealth head users please step inside [Re: shoebox] #924836
02/09/11 10:32 PM
02/09/11 10:32 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I would PM Chrisf regarding the Customer service and quality of the 440Source stuff. Chris is a straight up guy and won't steer you wrong.
Sheldon
Re: stealth head users please step inside [Re: shoebox] #924837
02/09/11 10:40 PM
02/09/11 10:40 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Got a set on my 440.Had 3 shops look them over,no problems.I changed springs,locks and retainers,no problems with them at all. Did have to clearance for pushrods.
Nautilus Racing-
Re: stealth head users please step inside [Re: Chris2581] #924838
02/09/11 10:58 PM
02/09/11 10:58 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
im liking these replies! mid 10s 127 are talkin my language! whats up with the headgasket thing.. source told me they recommend felpro XXXX gasket i dont remember which but it came out to 37thou which would be ok for me.
Re: stealth head users please step inside [Re: shoebox] #924839
02/09/11 11:00 PM
02/09/11 11:00 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
as far as the 3/8th pushrod clearance is there much meat that needed to be removed? i wonder if i could do that clearancing before i even put them on?
Re: stealth head users please step inside [Re: shoebox] #924840
02/09/11 11:02 PM
02/09/11 11:02 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
cool nice car BTW
THANKS...Thats his 2300.00 drag car....it was 1300.00 til he got the Stealths....LOL
He's been saving parts for 5 years to build it....cost him 1300.00 and ran 11.60's...The Stealths OOTB picked up .3 for him.
Re: stealth head users please step inside [Re: shoebox] #924841
02/09/11 11:05 PM
02/09/11 11:05 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I mocked the heads on my engine and started setting up the valvetrain,and marked the heads where they needed to be clearanced at, put 'em on the bench,then opened them up.EASY!!
Head gaskets?? I used the Fel Pro 8519PT1
Nautilus Racing-
Re: stealth head users please step inside [Re: shoebox] #924842
02/09/11 11:10 PM
02/09/11 11:10 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That's the way things should always be done
OMO there's no excuse for not checking "everything" before assembling a motor, especially with aftermarket parts
Just because it bolts on don't mean anything
Re: stealth head users please step inside [Re: Chris2581] #924843
02/09/11 11:27 PM
02/09/11 11:27 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I run them all last season (approx 300 passes). 440 +.030, 13.5:1 Ross pistons, Mopar Performance .590 solid cam, forged crank, Ohio Crankshaft H beam rods, ARP 2000 bolts, 2" Hooker super comp headers, Weiand Team G intake, 1050 dominater carb, Turbo Action "J" converter, 4.56 dana in a 3200 lb E body. 10.38/126.6 in 1/4 mile, 6.56/103 in 1/8.
Like everyone else, I had to clearance for push rods, change springs, retainers and locks. I also had to make a small amount of clearance in the combustion chamber to clear the piston dome around the spark plugs.
Over all, I'm pleased. The best part is the light weight.
Brian Dunnigan
Re: stealth head users please step inside [Re: shoebox] #924844
02/10/11 07:12 AM
02/10/11 07:12 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The advantage of the Stealth Head is:
#1. looks almost like a stock Head.
#2. Stock spark plug location will clear manifolds and headers designed for stock heads.
#3. Flow better than stock
#4. hardened Exhaust seats, No problem running Unleaded fuel.
#5. A lot lighter than stock.
#6. Affordable, not much more cost than rebuilding stock heads.
Disadvantages:
#1. Not made in the USA.
#2. Out of the box flow slightly less than the Edelbrock RPM.
#3. May need pushrod clearancing.
Unknowns:
#1. Customer service? I have not had any problems, but I have not tried to return anything.
#2. Quality issues? Some have posted on here about quality issues. I have no way to verify their issues. The heads that I have checked out fine, and I know several others who have had no problems with them either, but we have not torn down the engine to re-inspect the heads.
With the Stealth or Edelbrock heads you need to buy a head bolt kit that has the reduced wrench size bolts. The Angled spark plugs of the Edelbrock heads should provide a better plug location in the chamber for performance, but it can cause fitment issues with some headers and exhaust manifolds.
If you are going to run a solid cam, or really agressive hydraulic cam you will need to change out the springs/retainers/locks on either cylinder head. The stealth springs/retainer/locks should handle the same cams that the edelbrock heads do.
If you are looking for a performance head, and don't care what it looks like, you may be better off starting with the Victor, or Indy heads, rather then spending $1,000+ on the Stealth/RPM type heads then spending another $1,000+ to have them ported.
Re: stealth head users please step inside [Re: 451Mopar] #924845
02/10/11 07:27 AM
02/10/11 07:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
This old thread i posted some photos of when i got my stealth heads in Jan 2009:
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: stealth head users please step inside [Re: shoebox] #924846
02/10/11 09:11 AM
02/10/11 09:11 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Wasn't the combustion chamber too large or out of round and the gasket overhangs. That was why some had to weld up the chamber or get a head gasket for a larger bore???
Page 1 of 3 1 2 3
