Re: stealth head users please step inside
[Re: shoebox]
#924831
02/09/11 09:18 PM
02/09/11 09:18 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i've run mine for about 18-24 months. running supplied locks/retainers springs after checking.i use a purple 509 cam. machined to 78cc chamber and pocket ported. i also had to clearance for 3/8 smith brothers pushrods i used cometic gaskets from Don Gould work great daily driven and regularly raced on pump gas Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#924832
02/09/11 09:22 PM
02/09/11 09:22 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Tex
I wouldn't get to upset about it. I had to clearence my Eddy heads for the 3/8's pushrods.
[Re: WILD BILL]
#924833
02/09/11 09:25 PM
02/09/11 09:25 PM
tex013
Sydney,Australia
i swapped from iron 906's-no worries.didn't find out till heads were on motor was in car grrr. lots of masking off Tex
[Re: tex013]
#924834
02/09/11 09:52 PM
02/09/11 09:52 PM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
I did the same thing!
[Re: shoebox]
#924837
02/09/11 10:40 PM
02/09/11 10:40 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Got a set on my 440.Had 3 shops look them over,no problems.I changed springs,locks and retainers,no problems with them at all. Did have to clearance for pushrods.
[Re: shoebox]
#924840
02/09/11 11:02 PM
02/09/11 11:02 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
cool nice car BTW
THANKS...Thats his 2300.00 drag car....it was 1300.00 til he got the Stealths....LOL He's been saving parts for 5 years to build it....cost him 1300.00 and ran 11.60's...The Stealths OOTB picked up .3 for him.
[Re: shoebox]
#924842
02/09/11 11:10 PM
02/09/11 11:10 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
i wonder if i could do that clearancing before i even put them on?
That's the way things should always be done OMO there's no excuse for not checking "everything" before assembling a motor, especially with aftermarket parts Just because it bolts on don't mean anything
[Re: Chris2581]
#924843
02/09/11 11:27 PM
02/09/11 11:27 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I run them all last season (approx 300 passes). 440 +.030, 13.5:1 Ross pistons, Mopar Performance .590 solid cam, forged crank, Ohio Crankshaft H beam rods, ARP 2000 bolts, 2" Hooker super comp headers, Weiand Team G intake, 1050 dominater carb, Turbo Action "J" converter, 4.56 dana in a 3200 lb E body. 10.38/126.6 in 1/4 mile, 6.56/103 in 1/8. Like everyone else, I had to clearance for push rods, change springs, retainers and locks. I also had to make a small amount of clearance in the combustion chamber to clear the piston dome around the spark plugs. Over all, I'm pleased. The best part is the light weight. Brian Dunnigan
[Re: shoebox]
#924844
02/10/11 07:12 AM
02/10/11 07:12 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
The advantage of the Stealth Head is: #1. looks almost like a stock Head. #2. Stock spark plug location will clear manifolds and headers designed for stock heads. #3. Flow better than stock #4. hardened Exhaust seats, No problem running Unleaded fuel. #5. A lot lighter than stock. #6. Affordable, not much more cost than rebuilding stock heads.
Disadvantages: #1. Not made in the USA. #2. Out of the box flow slightly less than the Edelbrock RPM. #3. May need pushrod clearancing.
Unknowns: #1. Customer service? I have not had any problems, but I have not tried to return anything. #2. Quality issues? Some have posted on here about quality issues. I have no way to verify their issues. The heads that I have checked out fine, and I know several others who have had no problems with them either, but we have not torn down the engine to re-inspect the heads.
With the Stealth or Edelbrock heads you need to buy a head bolt kit that has the reduced wrench size bolts. The Angled spark plugs of the Edelbrock heads should provide a better plug location in the chamber for performance, but it can cause fitment issues with some headers and exhaust manifolds. If you are going to run a solid cam, or really agressive hydraulic cam you will need to change out the springs/retainers/locks on either cylinder head. The stealth springs/retainer/locks should handle the same cams that the edelbrock heads do.
If you are looking for a performance head, and don't care what it looks like, you may be better off starting with the Victor, or Indy heads, rather then spending $1,000+ on the Stealth/RPM type heads then spending another $1,000+ to have them ported.
[Re: shoebox]
#924846
02/10/11 09:11 AM
02/10/11 09:11 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
im liking these replies! mid 10s 127 are talkin my language! whats up with the headgasket thing.. source told me they recommend felpro XXXX gasket i dont remember which but it came out to 37thou which would be ok for me.
Wasn't the combustion chamber too large or out of round and the gasket overhangs. That was why some had to weld up the chamber or get a head gasket for a larger bore???
