DEAD DAKOTA *DELETED* #924567
02/09/11 03:21 PM
02/09/11 03:21 PM
OHIO
BUBBAZ572 Offline OP
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
Post deleted by BUBBAZ572
Re: DEAD DAKOTA [Re: BUBBAZ572] #924568
02/09/11 03:33 PM
02/09/11 03:33 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Sounds like you've damaged the crank sensor at the rear of the engine/bellhousing.
Re: DEAD DAKOTA [Re: BUBBAZ572] #924569
02/09/11 03:35 PM
02/09/11 03:35 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Did you use all the sensors from the original engine? Was the distr (cam sensor) out of the engine? Did you use the original flex plate? Relays ok? You did put another 3.9L in right?
Leave the gun.......take the Cannoli's....Mike
Re: DEAD DAKOTA [Re: mike s] #924570
02/09/11 03:36 PM
02/09/11 03:36 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
USED ALL OF THE SAME SENSORS.
Re: DEAD DAKOTA [Re: BUBBAZ572] #924571
02/09/11 03:44 PM
02/09/11 03:44 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Cam sensor is correctly located? Rotor is turning?
Re: DEAD DAKOTA [Re: mike s] #924572
02/09/11 03:49 PM
02/09/11 03:49 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Did you check for power at the ASD relay? And is it operating?
Re: DEAD DAKOTA [Re: Todd] #924573
02/09/11 03:53 PM
02/09/11 03:53 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
CAM SENSOR IS OK,ROTOR IS TURNING, CHANGED THE ASD RELAY.
Re: DEAD DAKOTA [Re: BUBBAZ572] #924574
02/09/11 03:58 PM
02/09/11 03:58 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Do you get the 2 second running of the pump, once you turn key on?
Re: DEAD DAKOTA [Re: buildanother] #924575
02/09/11 04:05 PM
02/09/11 04:05 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
PUMP WILL NOT RUN.
CAN MAKE IT RUN BY JUMPING ACROSS RELAY BUT THE ENGINE WILL STILL NOT RUN.
Re: DEAD DAKOTA [Re: buildanother] #924576
02/09/11 04:06 PM
02/09/11 04:06 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
If you can touch the relays while someone turns the key on and off you can check them for power,they should click on and off w/the ign switch.
Re: DEAD DAKOTA [Re: mike s] #924577
02/09/11 04:14 PM
02/09/11 04:14 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
unlock your caps !!!!
I am truckless..
Re: DEAD DAKOTA [Re: 340SHORTY] #924578
02/09/11 04:44 PM
02/09/11 04:44 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No need to yell at us.
Re: DEAD DAKOTA [Re: mike s] #924579
02/09/11 04:54 PM
02/09/11 04:54 PM
OHIO
MR. CAPS LOCK
MR. CAPS LOCK
OHIO
RELAYS ARE GOOD
Re: DEAD DAKOTA [Re: BUBBAZ572] #924580
02/09/11 05:03 PM
02/09/11 05:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Bubba's reply to our simple request to turn off the caps. Nice guy isn't he. I guess he doesn't understand internet manners.
"NOT YELLING
YOU ARE AN ASS
DO NOT RESPOND IF YOU DO NOT HAVE A SOLUTION TO PROBLEM"
Re: DEAD DAKOTA [Re: mike s] #924581
02/09/11 05:07 PM
02/09/11 05:07 PM
superwrench Offline
superwrench  Offline
Sorta where I was coming from when I mentioned the crank sensor. I've see so many that were cracked in the engine change process and then a no start.
If that Distributor was taken out and not put back in EXACTLY in the position it came out, the distributor will be out of phase and probably not start. The computor needs to see a cam and crank signal to run the fuel pump.
Do you get the fuel pump "priming" for 2 seconds when you first hit the key to "ON"?
Re: DEAD DAKOTA [Re: superwrench] #924582
02/09/11 05:13 PM
02/09/11 05:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
He just PMed me this. He really knows how to follow the rules about profanity here doesn't he. I guess things like that don't pertain to him. This kind of stuff from a guy that's been here for 4 years and post 55 times all asking for help and never helping anyone in return.
"NOW I AM YELLING, [Edited by Moparts - Family Friendly Site - Keep it clean] HEAD"
Re: DEAD DAKOTA *DELETED* [Re: BUBBAZ572] #924583
02/09/11 05:37 PM
02/09/11 05:37 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
Good job.
Earning every penny of that moderator paycheck.
DBAP
Re: DEAD DAKOTA *DELETED* [Re: not_a_charger] #924584
02/09/11 06:15 PM
02/09/11 06:15 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Good job.
Agreed , If you ask a question and moparts members take the time to answer your question, Why then do you feel the need to delete your question?
What your so important the NO one else will benefit from the info or you just so block headed that you think your the only one that should read the thread
Maybe we should just start deleting accounts of members that do this
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: DEAD DAKOTA *DELETED* [Re: moparts] #924585
02/09/11 07:09 PM
02/09/11 07:09 PM
Pretty please?
DBAP
Re: DEAD DAKOTA *DELETED* [Re: not_a_charger] #924586
02/09/11 08:02 PM
02/09/11 08:02 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IF YOU DONT HAVE A ANSWER DO NOT RESPOND
He PMd me the above statment
I am truckless..
