Alternator Question?
#924520
02/09/11 03:12 PM
02/09/11 03:12 PM
Posts: 55 Oklahoma
smokkem
Oklahoma
Looking for input on which alternator to buy for my 71 smallblock cuda with air.
Re: Alternator Question?
[Re: smokkem]
#924521
02/09/11 05:13 PM
02/09/11 05:13 PM
RapidRobert
I'd suggest the 78 amp one from late 70's (I forget the exact year/app) & ground (1) field lead if your on the old system & clean ALL the terminals everywhere including the ammeter terminals and seperate the bulkhead halves that have the (2) main in/out large wires (the lead from the alt and the lead past the fusible link) & ESPECIALLY clean those 2 pairs of brass terminals and you will b fine. A small metal bristle brush works on the male ones and a new male brass terminal works well on the female ones NAPA 725145 (might be 725147 I forget which) ~ 44 cents ea
[Re: Andrewh]
#924525
02/09/11 09:23 PM
02/09/11 09:23 PM
RapidRobert
Are you adding some extra electrical draws such as a stereo etc or just wanting a better alt than the oe '71 one? If you keep the stock ammeter needle close to 12 0'clock you'll b fine which means little flow in or out and I would highly suggest cleaning all the connections which is time consuming as they are 40 yr old
[Re: smokkem]
#924527
02/10/11 01:00 AM
02/10/11 01:00 AM
RapidRobert
Along w a better alt might consider powering all the additions w relays from the alt side so it feeds them right there from the source to elim heavy amperage going in/out thru the bulkhead which causes alot of the probs and adding a fusible link on the alt output stud 2 sizes smaller than the line ie 12 ga FL for an 8 ga line.
[Re: smokkem]
#924528
03/10/11 01:33 AM
03/10/11 01:33 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Yes I have 1500 watts of sterio amplifier, ...<snip!>
1500 watts at 13 volts = 115 Amperes, and that's assuming 100% efficiency in the amplifier!
If it is truly 1500 watts, you'll need an alternator rated more like 150 A. minimum, and some serious wiring -- in the range of #0 AWG wire (solid copper, and that's NOT a typo, number zero). And that assumes just the other typical loads - high beams, wiper motor, ignition system, heater blower, etc.
Rick
[Re: Rick_Ehrenberg]
#924529
03/10/11 12:44 PM
03/10/11 12:44 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
1500 watts alt, even being true, won't suck that ammount of power unless top volume, just some peaks accordin with dinamic range of music.
My advice is use a capacitor to keep safe the alt ( whichever alt you use ) to keep power to peaks
and with ammeter in line, feed everything from alt side, not from batt
[Re: NachoRT74]
#924530
03/10/11 01:20 PM
03/10/11 01:20 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Capacitors are a marketing gimick. They just don't store enough power or recharge quickly enough to be of any use on a serious system. If your alternator can't keep up in the first place, how is adding another power sucking device going to help? If you want some serious reserve capacity for your stereo or your hotrod, check out one of these. They'll smoke any cap you try to put in a system as a bandaid, and start your car good too. Check out thes discharge rates theses batteries pump out. They make smaller ones too. http://www.odysseybatteries.com/battery/pc2150.htm
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#924531
03/10/11 01:49 PM
03/10/11 01:49 PM
NachoRT74
Valencia, España
Capacitor are just for the peaks on Stereos... like Bass bumps and they work as far they are correctly rated and set on the system. They are not THE solution, just transitory on some systems
Some ppl have though they ARE the solution and thats why could be considered as "gimick". They have simply his specific application. Lot of ppl OVERAPPLICATES those.
( something like add a performance cam without think on TC... or change batt for a more reserve batt without step up the alt too )
not ANY capacitor work, and they don't work to become on a CONSTANT source.
Anyway, a bigger alt is mandatory though
