disc brake caliper placement question #924414
02/09/11 01:24 PM
02/09/11 01:24 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
Should the caliper be in the front of the set-up or the rear(9 o'clock or 3 o'clock)? Example in picture is drivers side, but I think I got it wrong.
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: disc brake caliper placement question [Re: 68 Sat] #924415
02/09/11 01:40 PM
02/09/11 01:40 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
There is no right or wrong place persay. If you can run your brake hose than you are fine. Mopars 69 and back had the caliper in that position it wasn't until 70 that these moved them up front.
Re: disc brake caliper placement question [Re: moparpollack] #924416
02/09/11 02:47 PM
02/09/11 02:47 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Re: disc brake caliper placement question [Re: moparpollack] #924417
02/09/11 04:23 PM
02/09/11 04:23 PM
QLD Australia
Keith Black® Offline
QLD Australia
I put mine at the rear
Darren Beale
Keith Black Racing Engines®
Re: disc brake caliper placement question [Re: 68 Sat] #924418
02/09/11 05:14 PM
02/09/11 05:14 PM
AndyF Offline
AndyF  Offline
Brake hose routing works the best if the hose crosses the spindle. But, you can do it either way and make it work. It just is easier if you cross the spindle because that gives you more room to work with. Almost all of the factory designs used a hose that crossed the spindle for that reason.
Re: disc brake caliper placement question [Re: AndyF] #924419
02/09/11 05:22 PM
02/09/11 05:22 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Just make sure the bleeder ends up on the top.
On my '64, I put the calipers on the rear because of interference with the sway bar. Had to hunt around for hoses that would work right and ended up with '73 Charger ones.
Re: disc brake caliper placement question [Re: AndyF] #924420
02/09/11 05:29 PM
02/09/11 05:29 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Nothing else to add, except for this
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: disc brake caliper placement question [Re: BloFish] #924421
02/09/11 07:57 PM
02/09/11 07:57 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
thanks guys.. I'll proceed to the other side and take a few shots when I'm all done.
