whats the corect 1969 1/2 440-6 fuel pump #923187
02/07/11 06:39 PM
02/07/11 06:39 PM
iowa
Carlen Offline OP
Carlen  Offline OP
iowa
lookink for the right replacement fuel pump and where to get it for my a-12, thanks
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: Carlen] #923188
02/07/11 08:55 PM
02/07/11 08:55 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
If you aren't looking for NOS the Carter part#gm4845 looks right. You will need to get the brass fitting for the pump to vapor sep. line.
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: FJ5_Fish] #923189
02/07/11 09:27 PM
02/07/11 09:27 PM
iowa
Carlen Offline OP
Carlen  Offline OP
iowa
i bought that exact pump you are showing- M-4845. i also bought that 389.00 six pack kit from hoover with the fuel lines etc, the thread size of the fuel line is to large for the fuel pump though, im guessing the small sort of S shaped fuel line is supose to screw into the pump, leading up to the fuel filter, witch leads up to the fuel line toward the carburator. and the crimp hose clamp end of the fuel pump leads toward the tank line. am i wrong or is there supose to be an addapter or what? if so what dose it look like and where do i get it, thanks carlen
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: Carlen] #923190
02/07/11 09:54 PM
02/07/11 09:54 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Yes - I mentioned the brass fitting in my above post. I know Y-One sells them - anyone else?
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: FJ5_Fish] #923191
02/07/11 09:57 PM
02/07/11 09:57 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Installed...
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: FJ5_Fish] #923192
02/07/11 10:20 PM
02/07/11 10:20 PM
iowa
Carlen Offline OP
Carlen  Offline OP
iowa
thanks for the info on the fitting, now as far as the crimp hose clamp type fittings, how do you go about clamping them down without buying a specil tool for just a couple of clamps. and thanks for the picture of the fuel pump and fitting. i got started building this engine a couple of years ago and just got it back from the builder, needless to say ive missed placed several parts and my memmory isnt what it used to be. thanks carlen
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: Carlen] #923193
02/07/11 10:43 PM
02/07/11 10:43 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
I don't think the tool is expensive and it makes the job E-Z
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: FJ5_Fish] #923194
02/07/11 10:57 PM
02/07/11 10:57 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
shelled out the $18 for the special crimping tool..your gonna need it at the tank as well.
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: LYNCHROAD69.5] #923195
02/07/11 11:30 PM
02/07/11 11:30 PM
iowa
Carlen Offline OP
Carlen  Offline OP
iowa
your right 18.00 not bad.
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: Carlen] #923196
02/08/11 12:04 AM
02/08/11 12:04 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Have you tried the parts wanted section? There's a lot of vendors who check it out.
Re: whats the corect 1969 1/2 440-6 fuel pump [Re: LYNCHROAD69.5] #923197
02/08/11 09:30 AM
02/08/11 09:30 AM
PA
BTTG Offline
BTTG  Offline
PA
What tool specifically?????
Will this work or is there something better to use (effectiveness rather than $)?
http://www.summitracing.com/parts/OTC-4723/
