68 Coronet Carpet ? #922918
02/07/11 01:14 PM
02/07/11 01:14 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline OP
Is the carpet out of a 68 coronet, console automatic the same as the console 4 speed car.
Re: 68 Coronet Carpet ? [Re: 268RTs4ME] #922919
02/07/11 05:38 PM
02/07/11 05:38 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I don't know if there is a difference at all. But if you are looking to buy stuff check out this: https://board.moparts.org/ubbthreads/show...e=0#Post6460004
Dante is the man to buy interior stuff from.
Re: 68 Coronet Carpet ? [Re: 268RTs4ME] #922920
02/07/11 08:39 PM
02/07/11 08:39 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
No the tunnels are different....
Re: 68 Coronet Carpet ? [Re: QuickBpBp] #922921
02/07/11 10:35 PM
02/07/11 10:35 PM
Kansas
BEINGmeISaCRIME Offline
Kansas
Yeah, they're different.
Yearone shows 2 different options for carpet: Automatic or 4-speed.
Re: 68 Coronet Carpet ? [Re: BEINGmeISaCRIME] #922922
02/08/11 01:29 AM
02/08/11 01:29 AM
2
Thank you, I guess I need to sell this new auto carpet, and buy me some 4 speed carpet, bought it new, still in the box, need to list it in parts for sale and buy me some 4 speed console carpet, thanks for the info.
Re: 68 Coronet Carpet ? [Re: 268RTs4ME] #922923
03/27/11 07:34 PM
03/27/11 07:34 PM
MN
mkvien Offline
mkvien  Offline
MN
Unfortunately only after I struggled installing my new carpet did I decide to log on and see what the experts say about it. I bought new carpet for my 68 Coronet 440 (R/T Clone). It has bucket seats, auto, no console. I have it in there and it it nice and tight over the driveshaft hump alongside the seats, but when I bolted the ratchet shifter down to the hump a little forward of the seats I get a big bulge on either side of the hump around that shifter and forward, basically from the front part of the seat to the firewall. Ordered it from these guys
http://www.trimparts.com
through eBay and didn't realize until 5 months later when I finally got it in the car and doing the install that they must have sent me the wrong stuff.
I guess at least I know what the problem must be, the extra carpet bulging up must be for the 4-speed hump (that is not there).
Re: 68 Coronet Carpet ? [Re: mkvien] #922924
03/27/11 11:31 PM
03/27/11 11:31 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Or the stock shifter is designed to mount to the welded brackets on floor, and you are bolting an aftermarket shifter directly to tunnel, and there's where the bulges are coming from. I had a 4 speed carpet that had a definite bulge-shifter allowance area on drivers side of hump.
Re: 68 Coronet Carpet ? [Re: buildanother] #922925
03/27/11 11:49 PM
03/27/11 11:49 PM
MN
mkvien Offline
mkvien  Offline
MN
I wanted a replacement for the carpet that was in there before, auto on the colum and no console, that's what I told them, but I think I ended up with something different. The car was originally a bench seat, auto on the column, I just swapped to buckets and a Quicksilver shifter, so there is nothing between the seats. Just wanted the carpet flat over the tunnel like it was originally.
I don't think I quite understand what you are saying, can you claify for me?
Thanks.
Re: 68 Coronet Carpet ? [Re: mkvien] #922926
03/28/11 12:13 AM
03/28/11 12:13 AM
chicagoland,usa
chicagoland,usa
I get what you're saying now, and did you have to trim any material off of the outsides of carpet? Last couple I had, that's what was nec to get carpet to lay down nicely.
Re: 68 Coronet Carpet ? [Re: buildanother] #922927
03/28/11 12:38 AM
03/28/11 12:38 AM
MN
mkvien Offline
mkvien  Offline
MN
I was hoping I could just pull it outwards and trim the extra, but it doesn't seem to work out that way. It lays correctly over the tunnel between the seats, and nice and flat under the seats as well, and probably up by the firewall too, but there is that bulge in between there that is going to be tough to get rid of.
Re: 68 Coronet Carpet ? [Re: mkvien] #922928
04/04/11 12:18 AM
04/04/11 12:18 AM
MN
mkvien Offline
mkvien  Offline
MN
Contacted the company, they wanted the part number off of the original box. Of course my luck the kids helped me clean up the shop 2 days earlier and it went out with the trash. I told them that sent them all the info I had and a couple pictures. Short version is either they sent me the wrong carpet or this is some of the worst fitting carpet I have ever seen.
I have it pulled as tight as I can around the seat area (in fact a little too tight on the driver's side creating a little gap along the tunnel) to try to get the extra out. You can see there is a lot of extra carpet around my shifter, right where the 4-speed hump would be.
