I added the off road spring loaded needle and seats
I got the eddie duel feed line for a thunder searies carb,then drilled/tapped the other side of my performer carb top to mount the duel feed line
get ready for the price of that fuel line though
I have seen no one else running one,I think I was the only smow to buy it at that price too!
and it dont come with a eddie filter like the single fuel line does either
got over 150$ in the duel feed line from carb to pump with -6/braided line/fittings/filter
works good,looks good,cost a heck of a lot though
if i was to do it again,I would just get 2 -an carb fittings use some -an 90*s and make a duel feed line from the braided hose and forget about the eddie hard line set up
