sadi roller vs billet roller w/bronze and steel gear
#922235
02/06/11 01:34 PM
02/06/11 01:34 PM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
hey guys i have decided on going roller,ok i know sadi rollers are cast does this mean you can use a stock oil pump shaft with steel gear????next question can you get a true 8620 billet roller cam with a cast gear??i want to avoid running a bronze gear altogether cause its going to be a street car..
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: sadi roller vs billet roller with bronze gear
[Re: JohnRR]
#922237
02/06/11 02:24 PM
02/06/11 02:24 PM
sublimehemi
sandwich IL
sadi is a cast not billet roller,the price differnce is like 25 bucks,if you dont specify this when you order a cam they will send you a sadi cast cam and not the 8620 billet....
[Re: sublimehemi]
#922238
02/06/11 03:10 PM
02/06/11 03:10 PM
Posts: 8,879 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Must be some fly-by-night cam company. I'd go out on a limb by saying that all performance solid roller cams are billet. Hydraulic roller cams "might" be cast depending on the manufacturer but they sure as hell wouldn't surprise you with it!
[Re: Stanton]
#922239
02/06/11 03:43 PM
02/06/11 03:43 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
every solid roller I have ever gotten was billet
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: quick77rt ]
#922242
02/06/11 05:34 PM
02/06/11 05:34 PM
dusturbd340W5
Kissimmee Fl.
CompCams,they sell plenty of solid roller grinds on cast cores. Mopars are a little harder to come by cast cores at least for BB mopars. SB's come with a cast core that's often reground,but your very limited to what you can do with that.
not saying it hasn't happened but I have never gotten a cast solid roller from comp or anyone else but I don't doubt that they are out there.
[Re: dusturbd340W5]
#922243
02/06/11 06:53 PM
02/06/11 06:53 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My point was that no reputable cam company would surprise you with a cast roller ... you'd know what you were getting either from the catalog or when you ordered it. Anyhow, to the OP's question ... Quote:
YES Quote:
There seem to be a few folks on here who think you can. However, I've yet to figure out how anyone could press on a gear that is smaller than the front cam journal !!! Explain that and I'll be a believer!
[Re: goldmember]
#922245
02/06/11 09:08 PM
02/06/11 09:08 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I guess that Comp is no longer reputable,in your words.
Nothing wrong with Comp ... -8 is cast, -9 is billet ... no surprises !!
[Re: Stanton]
#922246
02/06/11 09:16 PM
02/06/11 09:16 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
It's not suprising that your wrong,again. Order a PN 20-813-9 sounds like a billet core! That -9 means it is,that's what you are telling us. Wrong.It's a cast core. Again. Wow! What a suprise.
[Re: goldmember]
#922247
02/06/11 09:41 PM
02/06/11 09:41 PM
sublimehemi
sandwich IL
so guys are you sayin that if i do get an sadi cam ....a stock type steel gear will work....cause i dont want to replace a bronze gear at every oil change....i am not opposed on sadi they are used all the time with success but when your spring rates are crazy and you rev the engine high with a solid roller type lifters then a billet cam is a must...also there are alot of cams that look billet or have copper look to them or they machine down the casting in between the lobes that look billet but are not...the way you can tell if there is cnc marks in between the lobes..i think...
[Re: goldmember]
#922251
02/07/11 12:06 AM
02/07/11 12:06 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hmmm ... I'm looking at the Comp catalog and not only does it say -9's are solid billet but that particular core number falls under their heading of "RACE ROLLER CAM CORES - STEEL BILLET".
Maybe you just got screwed when you bought yours at the swapmeet ... I'd have it checked if I were you, it's probably just a stock hydraulic cam that someone scratched that # into!
