sadi roller vs billet roller w/bronze and steel gear
#922235
02/06/11 01:34 PM
02/06/11 01:34 PM
Posts: 373 sandwich IL
sublimehemi
sandwich IL
hey guys i have decided on going roller,ok i know sadi rollers are cast does this mean you can use a stock oil pump shaft with steel gear????next question can you get a true 8620 billet roller cam with a cast gear??i want to avoid running a bronze gear altogether cause its going to be a street car..
70 charger ,all aluminum 528 hemi 727 cope rmvb,680hp 670 tq,full sequential holley hp efi,full hotchkis tvs,qa1 k and lowers,borgeson steering box cass viper 11.75 with cass s-trac dana 3.54
Re: sadi roller vs billet roller with bronze gear
[Re: JohnRR]
#922237
02/06/11 02:24 PM
02/06/11 02:24 PM
sublimehemi
sandwich IL
sadi is a cast not billet roller,the price differnce is like 25 bucks,if you dont specify this when you order a cam they will send you a sadi cast cam and not the 8620 billet....
[Re: sublimehemi]
#922238
02/06/11 03:10 PM
02/06/11 03:10 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Must be some fly-by-night cam company. I'd go out on a limb by saying that all performance solid roller cams are billet. Hydraulic roller cams "might" be cast depending on the manufacturer but they sure as hell wouldn't surprise you with it!
[Re: Stanton]
#922239
02/06/11 03:43 PM
02/06/11 03:43 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
every solid roller I have ever gotten was billet
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: quick77rt ]
#922242
02/06/11 05:34 PM
02/06/11 05:34 PM
dusturbd340W5
Kissimmee Fl.
CompCams,they sell plenty of solid roller grinds on cast cores. Mopars are a little harder to come by cast cores at least for BB mopars. SB's come with a cast core that's often reground,but your very limited to what you can do with that.
not saying it hasn't happened but I have never gotten a cast solid roller from comp or anyone else but I don't doubt that they are out there.
[Re: dusturbd340W5]
#922243
02/06/11 06:53 PM
02/06/11 06:53 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
My point was that no reputable cam company would surprise you with a cast roller ... you'd know what you were getting either from the catalog or when you ordered it. Anyhow, to the OP's question ... Quote:
YES Quote:
There seem to be a few folks on here who think you can. However, I've yet to figure out how anyone could press on a gear that is smaller than the front cam journal !!! Explain that and I'll be a believer!
[Re: goldmember]
#922245
02/06/11 09:08 PM
02/06/11 09:08 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I guess that Comp is no longer reputable,in your words.
Nothing wrong with Comp ... -8 is cast, -9 is billet ... no surprises !!
[Re: Stanton]
#922246
02/06/11 09:16 PM
02/06/11 09:16 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
It's not suprising that your wrong,again. Order a PN 20-813-9 sounds like a billet core! That -9 means it is,that's what you are telling us. Wrong.It's a cast core. Again. Wow! What a suprise.
[Re: goldmember]
#922247
02/06/11 09:41 PM
02/06/11 09:41 PM
sublimehemi
sandwich IL
so guys are you sayin that if i do get an sadi cam ....a stock type steel gear will work....cause i dont want to replace a bronze gear at every oil change....i am not opposed on sadi they are used all the time with success but when your spring rates are crazy and you rev the engine high with a solid roller type lifters then a billet cam is a must...also there are alot of cams that look billet or have copper look to them or they machine down the casting in between the lobes that look billet but are not...the way you can tell if there is cnc marks in between the lobes..i think...
[Re: goldmember]
#922251
02/07/11 12:06 AM
02/07/11 12:06 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Hmmm ... I'm looking at the Comp catalog and not only does it say -9's are solid billet but that particular core number falls under their heading of "RACE ROLLER CAM CORES - STEEL BILLET".
Maybe you just got screwed when you bought yours at the swapmeet ... I'd have it checked if I were you, it's probably just a stock hydraulic cam that someone scratched that # into!
[Re: 602heavy]
#922255
02/07/11 02:03 PM
02/07/11 02:03 PM
goldmember
Gainesville,FL
Well , if you got a comp cam with the part# ending in -9 & it is'nt a billet core then you've been screwed over. .......maybe call comp cams & tell them the issue you had........Goldmember , did'nt you post something on speed talk regards this issue?
Nope. It's not an issue to me,just trying to pass along info that may help someone down the line. If someone other than Stanton needs this info just PM me with a phone # and I'll go over it again. Many comp cams ending in -9 that are cast cores(NOT ALL),catalog is incorrect,not a big deal for the application. Just don't like to hear the garbage being spewn as fact,although it's not uncommon. Can you tell which is the -9?
[Re: goldmember]
#922256
02/07/11 02:48 PM
02/07/11 02:48 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: goldmember]
#922258
02/07/11 03:21 PM
02/07/11 03:21 PM
Posts: 1,200 UK
602heavy
UK
Must of been an issue as you would'nt of posted over on speed talk , if i rememmber correctly you got no reply to you're question. ............ fact is the -9 IS a billet core , just because you got sent/sold the cast core does'nt mean we should all be aware -9s are NOT billet , the one on the left of you're picture is obviously a cast core .
[Re: 602heavy]
#922259
02/07/11 03:51 PM
02/07/11 03:51 PM
goldmember
Gainesville,FL
I ask about cores as I noticed comp was using cast cores with the -9 tag,yes, 4 different comp suppliers confirmed this. For that build I really wanted a 2pc core,which after working with Comp they were able to locate(although crane being done they had only a couple left) and I let them grind that cam. If I had ordered the same pn with that magical-9 through Jegs,Summit,etc I would recieve a CAST core as most running a hyd roller would be fine with that choice. For those that guessed the right was a -9 you were wrong,thats a crane billet(comp billets are -9),for those that guessed the cam on the left,you win!! Comp hyd roller cast core -9.Would you want a billet hyd roller cam and the pain of using a bronze gear on a mild build? I think several of you just missed my point completely.
[Re: goldmember]
#922262
02/07/11 05:14 PM
02/07/11 05:14 PM
BradH
I'm going to carefully step around the above and state exactly what I know on this subject: 1. There are no BBM / 426 Hemi billet cam cores w/ cast-iron gears pressed on available from any core source. 2. Although there have been cast cores used for performance roller cam applications for other brands, they have been given the by many engine builders because they don't hold up as well w/ the higher spring pressures that go along w/ those applications. You can do a search on cast roller cams on SpeedTalk.com to see some examples of this. 3. The only choice I have seen offered for hydraulic or solid rollers w/ a BBM or 426 Hemi is a billet steel cam that requires using the bronze distributor drive gear. I'm not thrilled about that either, but it is what it is at this time.
[Re: sublimehemi]
#922263
02/07/11 05:19 PM
02/07/11 05:19 PM
Posts: 1,200 UK
602heavy
UK
[Re: BradH]
#922264
02/07/11 05:40 PM
02/07/11 05:40 PM
goldmember
Gainesville,FL
Although I have been told(not verified!) that Ruben cams(grinds for others) has other core options. Again,I have no evidence to back this up.
[Re: Stanton]
#922267
02/07/11 07:09 PM
02/07/11 07:09 PM
goldmember
Gainesville,FL
"all along I've merely been quoting the Comp catalog." "Your statement below CLEARLY absolves me of any error." There's your problem. You believe everything you read,whether it's on the internet or in a catalog,it can easily be wrong. I'm not picking on you. If you think I owe you anything your sadly mistaken. A 4yr old with major ADHD can see that. I'll go down the street and borrow one(4 yr old ADHD kid) to confirm it if you like.
[Re: Stanton]
#922268
02/07/11 07:27 PM
02/07/11 07:27 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Ok, goldmember, I have no problem having an argument, being told I'm wrong or even admitting to being wrong - when I am! However, all along I've merely been quoting the Comp catalog. Your statement below CLEARLY absolves me of any error.
You owe me an apology. I don't think you're man enough!
