604 in limp mode UPDATE #92163
07/21/08 06:45 PM
07/21/08 06:45 PM
North Pole,New York
formula_s Offline OP
North Pole,New York
The 604 trans in my 92 went into limp mode, stuck in 2nd gear. I tried shutting it of to clear it , no help. I disconneted the batery overnight still didn't clear, What is the recommended fluid for a 604?? >>>>> UPDATE>>>> Had the trans scanned for codes. Three codes, one is "gear ratio error".
Re: 604 in limp mode [Re: formula_s] #92164
07/21/08 09:35 PM
07/21/08 09:35 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I don't know about a '92 model, but on more recent fwd trans, they go into limp mode when the input or output speed sensors on the trans go bad. I think they would be the modern equivilant of carrying a spare ballest resistor in your glove box on our old cars. But I don't yet have spare speed sensors in the glove box for my 300m. My bad.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 604 in limp mode [Re: GO_Fish] #92165
07/21/08 09:40 PM
07/21/08 09:40 PM
CENTRAL MINN
1965_PLYMOUTH Offline
CENTRAL MINN
remove the battery, and battery box. check your wiring harness for the transmission. mopars are well known for battery fluid leaking down into the harness and corroding the wires. if the harness looks good and clean, then I would put in a new input sensor. please keep us posted!!
Re: 604 in limp mode [Re: 1965_PLYMOUTH] #92166
07/21/08 09:47 PM
07/21/08 09:47 PM
kalispell montana
jwilson 61 Offline
jwilson 61  Offline
kalispell montana
A scan tool works wonders to find the problem don't just start remove and replace stuff ,that gets expensive quick. the money saved on proper diagnosis can then be put to proper repair. yes it could be as simple as a sensor or even a connector to the speed sensors but a scan tool will also tell you the clutch volumes and various other useful information it the only way to properly diagnose these trannys
70 cuda 440 6bbl Auto with a dana 60
68 road runner QQ1 383 auto
1970 6 barrel 4 speed Superbird FY1 number matching
15 Challenger 6.4 SRT pearl White 6 Speed
72 Cuda 440 5 speed
71 Road Runner 440 4 speed
Re: 604 in limp mode [Re: formula_s] #92167
07/21/08 09:49 PM
07/21/08 09:49 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
To answer your question about the fluid, it's either ATF+3 or ATF+4. Check your owners manual to be sure. DO NOT put Dexron or type F in it. I learned that lesson the hard way!
Re: 604 in limp mode [Re: formula_s] #92168
07/21/08 09:53 PM
07/21/08 09:53 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Before you do anything, find out what codes it has ?
ATF 4 is the only fluid I'd put in it
Re: 604 in limp mode UPDATE [Re: formula_s] #92169
11/03/11 11:06 AM
11/03/11 11:06 AM
North Carolina
apairof66s Offline
apairof66s  Offline
North Carolina
Is the dealership the only place to go to get the trans scanned for codes ???
Re: 604 in limp mode UPDATE [Re: apairof66s] #92170
11/03/11 11:31 AM
11/03/11 11:31 AM
Colorado
68FuryIIIColo Offline
Colorado
Most auto parts stores can scan it too but don't think they can clear the codes. Now in 92 I thought that was OBDI, The computer does not control the transmission does it? I think that is all hydro controlled.
Re: 604 in limp mode UPDATE [Re: 68FuryIIIColo] #92171
11/03/11 11:47 AM
11/03/11 11:47 AM
North Carolina
apairof66s Offline
apairof66s  Offline
North Carolina
Thanks for the reply.
The reason i'm asking is my wife's '93 LeBaron is in limp mode (reverse and 2nd gear only). It does have the trans. control module.
Re: 604 in limp mode [Re: JDMopar] #92172
11/03/11 12:18 PM
11/03/11 12:18 PM
ill
dennismopar73 Offline
ill
type of fluid has NOTHING TO DO WITH IT !
Re: 604 in limp mode [Re: dennismopar73] #92173
11/03/11 01:31 PM
11/03/11 01:31 PM
North Carolina
apairof66s Offline
apairof66s  Offline
North Carolina
my particular issue has nothing to do w/ the fluid fortunatley. the lebaron went into limp mode first and then we chg.d the fluid(+4), filter & gasket w/ no chg.
since then i've checked fuses, pulled and chk'd connectors to the sensors, along w/ the tcm, all with the battery disco'd. no chg.
i'm still thinking of having the codes read from the tcm.
