604 in limp mode UPDATE
#92163
07/21/08 06:45 PM
07/21/08 06:45 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
The 604 trans in my 92 went into limp mode, stuck in 2nd gear. I tried shutting it of to clear it , no help. I disconneted the batery overnight still didn't clear, What is the recommended fluid for a 604?? >>>>> UPDATE>>>> Had the trans scanned for codes. Three codes, one is "gear ratio error".
Re: 604 in limp mode
[Re: formula_s]
#92168
07/21/08 09:53 PM
07/21/08 09:53 PM
Posts: 21,456 It's a dry heat
gtx6970
It's a dry heat
Before you do anything, find out what codes it has ?
ATF 4 is the only fluid I'd put in it
Re: 604 in limp mode UPDATE
[Re: apairof66s]
#92170
11/03/11 11:31 AM
11/03/11 11:31 AM
Posts: 68 Colorado
68FuryIIIColo
Colorado
Is the dealership the only place to go to get the trans scanned for codes ???
Most auto parts stores can scan it too but don't think they can clear the codes. Now in 92 I thought that was OBDI, The computer does not control the transmission does it? I think that is all hydro controlled.
[Re: JDMopar]
#92172
11/03/11 12:18 PM
11/03/11 12:18 PM
Posts: 2,177 ill
dennismopar73
ill
To answer your question about the fluid, it's either ATF+3 or ATF+4. Check your owners manual to be sure. DO NOT put Dexron or type F in it. I learned that lesson the hard way!
type of fluid has NOTHING TO DO WITH IT !
