New Pistons Valve relief machined to edge is this OK? #921671
02/05/11 07:17 PM
02/05/11 07:17 PM
East Brunswick, NJ
finadk Offline OP
finadk  Offline OP
East Brunswick, NJ
I am assembling my 408 Stroker. These are custom made Ross Pistons and the valve relief's on all 8 are machined right to the edge of the piston. On three of them it is so close that it is below the top of the piston. Is this ok?
I will call Ross on Monday but figured i would get a response here pretty quick.
URL=http://rides.webshots.com/photo/2781308980028738248kQYVTF][/URL]
URL=http://rides.webshots.com/photo/2631684570028738248IHvAMP][/URL]
Re: New Pistons Valve relief machined to edge is this OK? [Re: finadk] #921672
02/05/11 07:25 PM
02/05/11 07:25 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes thats fine, as long as none of the edges get to a paper thin state. KB takes some of thier BB pistons all to to edge. You can rest your thumb in the in the dip and fit the curcature of it. mike
Re: New Pistons Valve relief machined to edge is this OK? [Re: finadk] #921673
02/05/11 08:41 PM
02/05/11 08:41 PM
I would deburr all the edges and the skirt edges on the bottom on both sides
Re: New Pistons Valve relief machined to edge is this OK? [Re: RapidRobert] #921674
02/05/11 08:46 PM
02/05/11 08:46 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Think hot spots
Re: New Pistons Valve relief machined to edge is this OK? [Re: Dcuda69] #921675
02/06/11 09:40 AM
02/06/11 09:40 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Think hot spots
Re: New Pistons Valve relief machined to edge is this OK? [Re: 6PACMAC] #921676
02/06/11 01:43 PM
02/06/11 01:43 PM
East Brunswick, NJ
finadk Offline OP
finadk  Offline OP
East Brunswick, NJ
Thanks Guys.
I appreciate the info and can sleep tonight.
Scott
Scott 1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed) 2002 Dodge Ram 1500 Quad Cab 1976 Corvette
