spline count on a 727 #921661
02/05/11 06:48 PM
02/05/11 06:48 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Does anyone know what the spline count on a 727 and what will interchange in a 727 big block and a 727 small block transmission I need to order a torque converter and don't want to pull the motor and trans just yet.
Re: spline count on a 727 [Re: KY Charger] #921662
02/05/11 06:54 PM
02/05/11 06:54 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
DON'T remember the exact spline-count ... but the converter swap you speak of ... no prob.
Re: spline count on a 727 [Re: KY Charger] #921663
02/05/11 06:55 PM
02/05/11 06:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
66 and up 727's were all the same as far as spline count big block or small block. Some convertors with cast crank engines had offset balance weights on them. Sorry I can't remember the exact spline count at this time.
Sheldon
Re: spline count on a 727 [Re: KY Charger] #921664
02/05/11 07:09 PM
02/05/11 07:09 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
24 spline.
Re: spline count on a 727 [Re: ireland383] #921665
02/05/11 07:15 PM
02/05/11 07:15 PM
Bowling Green, KY
K
K
Bowling Green, KY
I just didnt know if all 727 had the same spline count or some were different but looking at summit I think they are all 24 spline thanks for the info.
Re: spline count on a 727 [Re: KY Charger] #921666
02/05/11 07:22 PM
02/05/11 07:22 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
lock up trans are diff and do not interchange with non lock up !
dont forget internal and external balancing !
Re: spline count on a 727 [Re: calrobb2000] #921667
02/05/11 07:33 PM
02/05/11 07:33 PM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
I believe 66 & earlier are 19 spline
