if it was physically posible to fit on a 426Hemi... #921055
02/04/11 02:58 PM
02/04/11 02:58 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
Air conditioned... more specifically an RV2... was to be posible ?
I know 440s auto got them. Manuals, not I guess because the High revs or something like that. Six pack not no matter auto or manual same as Hemis, but I think due the poor room.
whats would make not to fit an RV2 on an HEMI auto beside the room.
Re: if it was physically posible to fit on a 426Hemi... [Re: NachoRT74] #921056
02/04/11 03:33 PM
02/04/11 03:33 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Your speaking of an original chrysler unit ? The hemi's heads with valve covers and intake set I believe higher in the engine compartment so room is the issue. I looked at that option when I was building my clone hemi cuda convertible because I wanted air on the engine, the best compact option that fit was the sanden compressor. I did alot of cosmetics to the compressor to make it look like it belonged even though we know hemi's didn't come with air. I removed all external mounting lugs except the ones I used to mount the unit, then smoothed the case and glass beaded. Sprayed the case semi-gloss black and used blackened hardware to install it, I thought the end results looked great.
logan426
Re: if it was physically posible to fit on a 426Hemi... [Re: MLR426] #921057
02/04/11 04:28 PM
02/04/11 04:28 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Got a pic?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: if it was physically posible to fit on a 426Hemi... [Re: MOPARMIKE69] #921058
02/04/11 04:35 PM
02/04/11 04:35 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Got a pic?
I'm not picture posting smart. Go to the buchillon pulley site. spelling may not be 100%,
and it will give you an idea of the mounting and set up.
logan426
Re: if it was physically posible to fit on a 426Hemi... [Re: MLR426] #921059
02/04/11 05:11 PM
02/04/11 05:11 PM
Valencia, España
Valencia, España
I'm just wondering about this due the power making some damage on the compressor ( yes, stock RV2 compressor ), belts or whatever... or maybe the small jumpy iddle making some damage...
so if you get more less same engine specs than a 426Hemi ( power and slightly jumpy iddle ), but with room to fit the stock RV2, will be a problem with that
Re: if it was physically posible to fit on a 426Hemi... [Re: NachoRT74] #921060
02/04/11 05:12 PM
02/04/11 05:12 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Pretty sure there was a 70 300 Hurst that had a hemi with an RV2 compressor in a mopar mag , I'm sure I have the mag in my collection. Think the claim in the mag was that is was factory built exec car.
Re: if it was physically posible to fit on a 426Hemi... [Re: MOPARMIKE69] #921061
02/04/11 06:08 PM
02/04/11 06:08 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Got a pic?
Re: if it was physically posible to fit on a 426Hemi... [Re: gtx6970] #921062
02/04/11 08:15 PM
02/04/11 08:15 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Mine with the full Bouchillon kit....
Butch
Re: if it was physically posible to fit on a 426Hemi... [Re: CHRYCOFAN] #921063
02/04/11 08:58 PM
02/04/11 08:58 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Part of the reason that the A/C wasnt available had to do with the massive girth of the pump unit, which sat right in the way of the front carburetor of the HEMI. A single 4 barrel would certainly help fitment.
I have seen guys mount the Sanden pump below the alternator. When they use an electric fuel pump, theres more room there....Hm......
Re: if it was physically posible to fit on a 426Hemi... [Re: Kern Dog] #921064
02/04/11 09:04 PM
02/04/11 09:04 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i had a buddy who had a 71 RT/SE recreation that had a 604 ci hemi with a indy single plane intake that had A/C with the original compressor.
he sold it to a guy in michigan who had it for a short time, he worked for chrysler. when the economy tanked he listed in the B bodies for sale for a while. i think his name was hemiviper or viper something.
perception is 90% of reality
Re: if it was physically posible to fit on a 426Hemi... [Re: Mr T2U] #921065
02/04/11 09:30 PM
02/04/11 09:30 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you use an electric fuel pump you can mount a Sanderson compressor under the alternator and route the hoses either through the firewall, or hide the majority of them by routing them through to cam bolt adjuster access hole in the inner fender well and back through the firewall under the fender. makes for a pretty stealthy A/C add on, especially if you want to keep the top of your engine bay uncluttered and stock appearing.
Re: if it was physically posible to fit on a 426Hemi... [Re: NachoRT74] #921066
02/04/11 10:12 PM
02/04/11 10:12 PM
San Jose, CA
Blue69Charger Offline
San Jose, CA
I installed the under-alternator kit from BPE on my 69 charger. I used their hose and condensor kit as well. I bought the mastercool hose crimper to make the hoses. It worked great on the -6 and -10 hoses but not at all on the -8 discharge hose. I tried making two -8 hoses and both times it made bad looking crimps that didn't seal, maybe I got a bad die. I ended up using aeroquip braided hose for the -8 discharge hose (it runs under the car and is not really visible). It was pricey but worked great. I would recommend the aeroquip hose for this setup if you don't mind the look. I left the drier in the factory location because there isn't much room between the radiator support and grill on a charger because of the vacuum, headlight assemblies. Overall the system works great and can get down to 16°F on a 65°F day. Having the compressor under the alternator makes it harder to work on the a/c (more work to get out, hard to get to the fittings), but it does look cleaner.
Re: if it was physically posible to fit on a 426Hemi... [Re: CHRYCOFAN] #921067
02/05/11 12:53 AM
02/05/11 12:53 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
Butch
Geeeez..I really,really like that Fury from the first time I laid eyes on it in your sig! Nice!
Re: if it was physically posible to fit on a 426Hemi... [Re: JohnRR] #921068
02/05/11 02:12 AM
02/05/11 02:12 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
but I'm not sure about the exec bit, could've been. I seem to recall three of these were built? Maybe convertibles?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: if it was physically posible to fit on a 426Hemi... [Re: Kern Dog] #921069
02/05/11 12:03 PM
02/05/11 12:03 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ummm , NO , the hemi was a RACE engine , there is no place on a race engine for air conditioning
Re: if it was physically posible to fit on a 426Hemi... [Re: 3hundred] #921070
02/05/11 04:51 PM
02/05/11 04:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There were no factory built 1970 Hurst 300 Chryslers built with Hemis, however, there are several that have been converted to hemi power running around
Re: if it was physically posible to fit on a 426Hemi... [Re: CHRYCOFAN] #921071
02/11/11 11:31 PM
02/11/11 11:31 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Nice setup, good way to run a "big cube" Hemi, in a SLEEPER package!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: if it was physically posible to fit on a 426Hemi... [Re: JohnRR] #921072
02/11/11 11:36 PM
02/11/11 11:36 PM
California
mickm Offline
mickm  Offline
California
i agree. it's a race engine. roll down the window.
car in sig picture: manual steering, manual brakes, manual air conditioning...
Re: if it was physically posible to fit on a 426Hemi... [Re: JohnRR] #921073
02/11/11 11:44 PM
02/11/11 11:44 PM
Desert Tracker
Desert Tracker
Riddle me this: If the HEMI IS a race engine, why are there so many roaming the streets in other
body packages beside it's "standard" production
chassis - the "B" Body!!
Re: if it was physically posible to fit on a 426Hemi... [Re: ScottSmith_Harms] #921074
02/12/11 12:00 AM
02/12/11 12:00 AM
Desert Tracker
Desert Tracker
with ya. Maybe a dealer option switch-a-roo?
There could have been a FACTORY option
on the 440 "Six Pack", but none on the HEMI.
