if it was physically posible to fit on a 426Hemi...
#921055
02/04/11 02:58 PM
02/04/11 02:58 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Air conditioned... more specifically an RV2... was to be posible ?
I know 440s auto got them. Manuals, not I guess because the High revs or something like that. Six pack not no matter auto or manual same as Hemis, but I think due the poor room.
whats would make not to fit an RV2 on an HEMI auto beside the room.
Re: if it was physically posible to fit on a 426Hemi...
[Re: NachoRT74]
#921056
02/04/11 03:33 PM
02/04/11 03:33 PM
Posts: 4,799 ILL
MLR426
ILL
Your speaking of an original chrysler unit ? The hemi's heads with valve covers and intake set I believe higher in the engine compartment so room is the issue. I looked at that option when I was building my clone hemi cuda convertible because I wanted air on the engine, the best compact option that fit was the sanden compressor. I did alot of cosmetics to the compressor to make it look like it belonged even though we know hemi's didn't come with air. I removed all external mounting lugs except the ones I used to mount the unit, then smoothed the case and glass beaded. Sprayed the case semi-gloss black and used blackened hardware to install it, I thought the end results looked great.
logan426
[Re: MOPARMIKE69]
#921058
02/04/11 04:35 PM
02/04/11 04:35 PM
Posts: 4,799 ILL
MLR426
ILL
Got a pic?
I'm not picture posting smart. Go to the buchillon pulley site. spelling may not be 100%, and it will give you an idea of the mounting and set up.
logan426
[Re: MLR426]
#921059
02/04/11 05:11 PM
02/04/11 05:11 PM
NachoRT74
Valencia, España
I'm just wondering about this due the power making some damage on the compressor ( yes, stock RV2 compressor ), belts or whatever... or maybe the small jumpy iddle making some damage...
so if you get more less same engine specs than a 426Hemi ( power and slightly jumpy iddle ), but with room to fit the stock RV2, will be a problem with that
[Re: Kern Dog]
#921064
02/04/11 09:04 PM
02/04/11 09:04 PM
Posts: 4,922 new berlin wisconsin
Mr T2U
i had a buddy who had a 71 RT/SE recreation that had a 604 ci hemi with a indy single plane intake that had A/C with the original compressor. he sold it to a guy in michigan who had it for a short time, he worked for chrysler. when the economy tanked he listed in the B bodies for sale for a while. i think his name was hemiviper or viper something.
perception is 90% of reality
[Re: CHRYCOFAN]
#921067
02/05/11 12:53 AM
02/05/11 12:53 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Mine with the full Bouchillon kit....
Butch
Geeeez..I really,really like that Fury from the first time I laid eyes on it in your sig! Nice!
[Re: Kern Dog]
#921069
02/05/11 12:03 PM
02/05/11 12:03 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Part of the reason that the A/C wasnt available had to do with the massive girth of the pump unit, which sat right in the way of the front carburetor of the HEMI. A single 4 barrel would certainly help fitment.
Ummm , NO , the hemi was a RACE engine , there is no place on a race engine for air conditioning
[Re: 3hundred]
#921070
02/05/11 04:51 PM
02/05/11 04:51 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
but I'm not sure about the exec bit, could've been. I seem to recall three of these were built? Maybe convertibles?
There were no factory built 1970 Hurst 300 Chryslers built with Hemis, however, there are several that have been converted to hemi power running around
[Re: JohnRR]
#921072
02/11/11 11:36 PM
02/11/11 11:36 PM
Posts: 4,179 California
mickm
California
i agree. it's a race engine. roll down the window.
car in sig picture: manual steering, manual brakes, manual air conditioning...
