Anybody use the LencoDrive or Lenco ST1200 on street? #92024
07/21/08 03:07 PM
07/21/08 03:07 PM
Tulsa, OK
73cudaproject Offline OP
Tulsa, OK
On anther post someone mentioned using a Lenco ST1200 on the street. I went to the Lenco website and sure enough they do make a manual transmission for the street.
http://www.lencoracing.net/ST1200MasterPage.html
Looks pretty wild and I imagine costly. Is anybody using this type of transmission on a street/strip car?
At this time I am not sure if the LencoDrive automatic is strictly for racing or also available in a street/strip version.
Re: Anybody use the LencoDrive or Lenco ST1200 on street? [Re: 73cudaproject] #92025
07/21/08 06:13 PM
07/21/08 06:13 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Check out the latest Hot Rod, the one with the 9 second Hemi Dart on the cover, street driven A/C and a Lenco 1200 with gear vendors OD. I want more info than thay published but looks like a real trick deal. Probably buckets full of $$$$$
Re: Anybody use the LencoDrive or Lenco ST1200 on stree [Re: Cudajon] #92026
07/21/08 07:53 PM
07/21/08 07:53 PM
Tulsa, OK
Tulsa, OK
You are right. The Hemi Dart in the Sept. '08 Hot Rod has a Lenco. The owner Gary says, "The Lenco freewheels in First through Forth gear when you get off the gas, which makes it very friendly to operate on the street. That means since there is no engine braking, you don't have to step on the clutch all the time when you are coasting to a stop." The owner says "Excess is good." In this case I think the Lenco is just about perfect.
Now I have something new to dream about. Imagine grabbing a gear with this type of setup...
Re: Anybody use the LencoDrive or Lenco ST1200 on stree [Re: 73cudaproject] #92027
07/21/08 09:07 PM
07/21/08 09:07 PM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
That absolutely pegs the cool meter. I'd love to see the look on the valet's face when you pull up to Chez Whitey strapping a lenco.
Re: Anybody use the LencoDrive or Lenco ST1200 on stree [Re: Pool Fixer] #92028
07/21/08 10:08 PM
07/21/08 10:08 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I know one guy who had a 3-speed lenco drive automatic in a cuda, and it was awesome!!!
Friends of mine run the st1200 4-speed manual in a rustang, and its also wild. Makes a whine when driving though.
Re: Anybody use the LencoDrive or Lenco ST1200 on street? [Re: 73cudaproject] #92029
07/22/08 07:51 AM
07/22/08 07:51 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Lenco's were developed because horsepower levels outgrew most standards and automatics. The downside (besides the size, numerous shifters and downshifting woes) are that they rob a lot of horsepower. You'll want some serious ponies before you consider one of these.
No doubt it would have some visual impact but I think driving with the thing would become a PITA real quick !!
