holley 6 bbl question #919855
02/02/11 08:24 PM
02/02/11 08:24 PM
north palm florida united stat...
mopar0723 Offline OP
I have a set of hollys 6 BBL sitting on 440, They have all recently been done,plated rebuilt etc,etc, I hooked a vacum gauge to the center carb port the one going to the distributor, ( the higher port of the 2 ) I am showing 5 in of vacum @ 825 rpm. Is this normal I have been told there should be none or almost nothing, If wrong what is problem ?
Thanks guys
Re: holley 6 bbl question [Re: mopar0723] #919856
02/02/11 08:37 PM
02/02/11 08:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Vacuum at the timed port at idle is usually caused by the throttle butterflies being too far open at idle, try closing the butterflies and using the mixture screws to set the idle.
Is the cam stock?
Re: holley 6 bbl question [Re: John_Kunkel] #919857
02/02/11 08:44 PM
02/02/11 08:44 PM
cam is fairly big but not shure what is in there ,I am assuming butterflys are closed, I look in and they seem closed, or ?
