67 B-Body disc brake conversion #919494
02/02/11 08:47 AM
02/02/11 08:47 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
My 67 gtx has factory disc brakes. I want to know if differant calipers and rotors can be use with the stock spindles. I don't like the stock 2 piece rotors 'cause there are no long wheel studs available. And the the 4 puc calipers are leaky. And they have already been resleeved in stainless. Will any of the newer stuff fit the stock spindles?
Re: 67 B-Body disc brake conversion [Re: 6PACMAC] #919495
02/02/11 08:52 AM
02/02/11 08:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Aftermarket like wilwood or areospace might have something , otherwise to go with later factory single piston stuff you need to replace the spindle .
Re: 67 B-Body disc brake conversion [Re: JohnRR] #919496
02/02/11 09:03 AM
02/02/11 09:03 AM
Backwoods of NC
Topher Offline
Topher  Offline
Backwoods of NC
You can use the spindles off an 88 Diplomat or New Yorker(rwd). I got a setup complete with proportioning valve for a friend's '66 Coronet for a $100.
Topher
topher@headlightmotorman.com
www.headlightmotorman.com
67 Charger 383 3 pedal car
[|||||||||o|||||||||]
Re: 67 B-Body disc brake conversion [Re: Topher] #919497
02/02/11 09:34 PM
02/02/11 09:34 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I'd like to hear more on this topic. I have Belvedere 1 w/factory discs that have warped rotors and really need to figure out a direction. Either fork over the big $$$ for factory replacement rotors that are hard to find or convert everything over to something else.
Re: 67 B-Body disc brake conversion [Re: Belvedere1] #919498
02/02/11 09:39 PM
02/02/11 09:39 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I swapped mine over to 74 Duster discs,spindles and all.Easy and cheap.
Keith
Re: 67 B-Body disc brake conversion [Re: Belvedere1] #919499
02/02/11 10:19 PM
02/02/11 10:19 PM
Backwoods of NC
Topher Offline
Topher  Offline
Backwoods of NC
What do you want to know?
Topher
Re: 67 B-Body disc brake conversion [Re: Topher] #919500
02/02/11 10:49 PM
02/02/11 10:49 PM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
All good responses . So, a mid 70's a-body set up or a late 80's diplomat. I guess maybe a aspen/ volary set up may work also? Very interesting . So the b-body ball joint studs aren't too big or thick?
Re: 67 B-Body disc brake conversion [Re: 6PACMAC] #919501
02/02/11 11:00 PM
02/02/11 11:00 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
To anyone who has used an aspen / volare slider setup . what flex line was used?
Re: 67 B-Body disc brake conversion [Re: 6PACMAC] #919502
02/02/11 11:59 PM
02/02/11 11:59 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Take a peek at MA Disc Swap
Note that the F/J/M knuckles mentioned above are taller and increase bumpsteer.
Rick
Re: 67 B-Body disc brake conversion [Re: Rick_Ehrenberg] #919503
02/03/11 01:25 AM
02/03/11 01:25 AM
S.W. PA
6PACMAC Offline OP
6PACMAC  Offline OP
S.W. PA
Your the man Rick .
Re: 67 B-Body disc brake conversion [Re: Belvedere1] #919504
02/03/11 02:11 AM
02/03/11 02:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought someone posted that centric , or ??? , made a rotor ?
Re: 67 B-Body disc brake conversion [Re: JohnRR] #919505
02/03/11 08:48 AM
02/03/11 08:48 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
calipers - www.calipersonline
rotor hats at www.durabreak.com
Re: 67 B-Body disc brake conversion [Re: gtx6970] #919506
02/03/11 09:40 PM
02/03/11 09:40 PM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Still not sure what is needed in addition to those "kits" that are out there. My car has factory power Bendix brakes. Is it possible to use the current power brake booster, master cylinder, and proportining valve?
All are in good working order except for the rotors that are @ the runout limit of .005 according to the shop manual.
Re: 67 B-Body disc brake conversion [Re: Belvedere1] #919507
02/03/11 09:50 PM
02/03/11 09:50 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I'm currently working on a 1969 Charger original Bendix disc brake car.
It's being upgraded to aspen/volare single piston calipers and rotors.
And I'm re-using the cars original/rebuilt disc brake master cylinder and booster and all the related valves .
