Re: fuel line and fenderwell headers
[Re: 500ci barracuda]
#918443
02/01/11 12:19 AM
02/01/11 12:19 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
I don't have a picture of my engine compartment showing the fuel line, I ran the 1/2 line in the same way as the stock 5/16 was ran by the factory My car is a 1971 Duster with a BB and fender well headers, the headers don't get close(close meaning less than 6 inches) to the fuel line anywhere other than when it hooks up to fuel regulator The fuel regulator is mounted on the backside of the elephant ears directly under the alternator, it might be close to six inches there. the motor and headers are out of the car right now so I can't measure them to see, sorry
[Re: SG duster]
#918445
02/01/11 07:50 AM
02/01/11 07:50 AM
Posts: 2,363 PA
70HemiGTX
PA
Here's mine
[Re: 70HemiGTX]
#918446
02/01/11 09:53 AM
02/01/11 09:53 AM
Posts: 101 Malvern Pa
500ci barracuda
Malvern Pa
I am asking this because nhra techs gave me a laundry list of stuff when I had my dart.one of the things was the fuel line.It had to run on the outside of the rail so if a ujoint or a clutch explosion it wouldn,t damage the fuel line.This is going to be manly a street car but I am going to play around at the track at times.I just don,t want no hassels from them.Places like maple grove are not kind to mopars
#918451
02/02/11 12:08 AM
02/02/11 12:08 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
Start out at the tank, run the line/braided hose next to the frame inside of the spring area, cross over to the outside of the frame area at the front and terminate at the pressure regulator on your inner fender well area, this could very for your preference but not on the firewall.
#918454
02/02/11 10:10 PM
02/02/11 10:10 PM
Posts: 16,928 NC
440Jim
NC
There is an exception in the rule book (check it out), enclose the fuel line in a 1/8" wall thickness steel pipe if you run it on the inside of the frame rail. This is how my car was changed to when the fenderwell headers were put hunging the outside of the frame rails.
