TTI headers & # 5 plug #917833
01/31/11 02:33 AM
01/31/11 02:33 AM
Idaho
K
kdtjb Offline OP
kdtjb  Offline OP
K
Idaho
By far most MOPAR people say use TTI headers, So I have bought no less than 5 sets. Call me a slow learner. My question is are all TTI users with stock heads running on 7 cylinders ? Or did they take a hammer to there brand new polished headers ? TTI has had years to fix this problem, but has yet to do so. I know I'm not alone on this. So let's call them out.
Re: TTI headers & # 5 plug [Re: kdtjb] #917834
01/31/11 09:56 AM
01/31/11 09:56 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It sure looks hard to get a socket on that plug, huh?
Is there any chance of slotting the mounting holes of the headers to allow them to move forward a little? 1/8 inch may be enough to get a socket on that plug. If you are concerned about port mismatch, try the header on a head on a work table. You may get lucky and find that the "ovalling" out of the holes actually helps the ports align better. Its worth a try.
Re: TTI headers & # 5 plug [Re: kdtjb] #917835
01/31/11 10:09 AM
01/31/11 10:09 AM
Jensen Beach, Florida
pressureangle Offline
Use a wrench instead?
Why do I torture myself so?
Re: TTI headers & # 5 plug [Re: pressureangle] #917836
01/31/11 10:12 AM
01/31/11 10:12 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I have one of the early Block Hugger TTI headers on a 400 stroker and have no problems reaching plugs with a scoket.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: TTI headers & # 5 plug [Re: Savoy1964] #917837
01/31/11 10:54 AM
01/31/11 10:54 AM
IL
71383beep Offline
71383beep  Offline
IL
I had issues with the #3 plug on the left side. Being used to having headers I posted a question on here asking what others have done and how best to live with it and instead someone from their end PM'd me personally and it turned out I had an older set and they had a new design in use that remedied my issue. They sent me a new left side and asked for mine back. I didn't pay 1 cent for this so in my book they ARE the best out there and are a stand up company.
have you spoken directly with anyone from TTI? Perhaps this is something that they may have worked out already?
BTW...I have never been able to use a socket on all of my plugs. I have had to use a wrench on at least 3 plugs. By far this is way better than some other headers out there. I can also use a socket on almost all of the header bolts too. Too me the bigger problem is dealing with the stupid coolant leaks that I never seem to get on top of!
'73 GK6 Challenger Rallye - 340 4-Speed
Re: TTI headers & # 5 plug [Re: 71383beep] #917838
01/31/11 02:16 PM
01/31/11 02:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have 2 inch CPPAs on the 65.They were some of the first.Mine are 2 inch.Ive never had a problem with #5.I run Taylor Spiro Pros and the are at least 10 years old.# 6 is the bear on mine.I usually take it out from under the car.Rocky
Chrysler Firepower
Re: TTI headers & # 5 plug [Re: therocks] #917839
01/31/11 08:24 PM
01/31/11 08:24 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
Have you tried a crow's foot?
Re: TTI headers & # 5 plug [Re: kdtjb] #917840
01/31/11 08:54 PM
01/31/11 08:54 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
You shoulda seen the set they sent me for my low deck stroker. Had to get their 383 headers w/ 1 3/4" primaries & they dented about 4 tubes. ALmost 1/2" deep, too.
Re: TTI headers & # 5 plug [Re: kdtjb] #917841
01/31/11 09:06 PM
01/31/11 09:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I am NOT a TTi fan but man yheaders require the use of a WRENCH on certain plugs. It's really not that big of a deal. And it's easier to get to some from under the car.
Coming soon!!!!
Re: TTI headers & # 5 plug [Re: Mr.Yuck] #917842
01/31/11 09:40 PM
01/31/11 09:40 PM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I have 2" Tti's on the 440 in my '62 Convertible. A socket will fit on #5 in my car. I don't understand all the complaining. On most of these big block early "B" cars changing plugs was just as much of a PITA with the original manifolds.
Re: TTI headers & # 5 plug [Re: TooMany62s] #917843
02/01/11 02:03 AM
02/01/11 02:03 AM
Idaho
K
kdtjb Offline OP
kdtjb  Offline OP
K
Idaho
No I can't even to began to get a socket on it. A wrench might work, but I'll still be running on 7 cylinders. The spark plug boot is touching the header. I can fix this problem with a hammer. It just seems that TTI would't want a bunch of brand new polished headers running around beat to a pulp.
Re: TTI headers & # 5 plug [Re: kdtjb] #917844
02/01/11 02:33 AM
02/01/11 02:33 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I have had a couple of sets of TTi headers on my RoadRunner and 440. The plugs can be a little tite but EZ to take out, just do it when they are cold. A couple of the plugs I use a short extension.
Just my $0.02..
Re: TTI headers & # 5 plug [Re: Sinitro] #917845
02/01/11 11:55 AM
02/01/11 11:55 AM
Idaho
K
kdtjb Offline OP
kdtjb  Offline OP
K
Idaho
I'm finally starting to get it. Running on 7 cylinders is ok.
Re: TTI headers & # 5 plug [Re: kdtjb] #917846
02/01/11 12:42 PM
02/01/11 12:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd say send them back but you've already beat on them. For the money TTi's cost they should jump out of the box and install themselves. These are $109 Summit headers and I didn't have to dink of beat one tube to get them on. All the plugs can be changed easy #5 is a tad rough but doable.
Re: TTI headers & # 5 plug [Re: kdtjb] #917847
02/01/11 01:00 PM
02/01/11 01:00 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
You're a little slow to catch on. There have been a few decent suggestions posted so far. Besides, if your motor is fouling plugs so bad that it needs frequent plug swaps, your problems are far greater than header fitment. There are several spark plug wire companies making products with heat protection. Look into it. Were all happy to help, but we are not here to do it for you.
Re: TTI headers & # 5 plug [Re: Kern Dog] #917848
02/01/11 01:07 PM
02/01/11 01:07 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
No his issue isn't changing the plugs like everyone keeps talking about.... His issue is the spark plug boot burns because it touches the header.... If the boot is touching then there is no room for "Heat Protection".... So when the spark plug boot is burnt to a crisp his car runs on seven cylinders..... Apparently the message he's getting is that burnt plug boots is acceptable with $700 headers... Where-as $150 headers generally don't have that issue....
Re: TTI headers & # 5 plug [Re: 1_WILD_RT] #917849
02/01/11 01:14 PM
02/01/11 01:14 PM
NY usa
540challenger Offline
NY usa
Not at all one member already posted he had the same problem with his TTI headers called TTI and sent him a new one at no cost to him. If he can't make it work and doesn't want to take the time to call TTI what more can be done
Re: TTI headers & # 5 plug [Re: 540challenger] #917850
02/01/11 01:23 PM
02/01/11 01:23 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
If the op wants help, he should be CLEARER in his request. Nobody is paid on this site to help, so we're not going to dig for answers to HIS problems. If he would have specifically stated the problem and then read the responses, it would have been MUCH easier.
Re: TTI headers & # 5 plug [Re: 540challenger] #917851
02/01/11 05:32 PM
02/01/11 05:32 PM
IL
71383beep Offline
71383beep  Offline
IL
Exactly! At no time did I read "...I spoke with TTI and they recommended..." instead it's turned into a "I hate TTI because..." bandwagon. If there is evidence that TTI blew him off then i would be more inclined to join in, but as i said before I was VERY impressed with their reaction. since then I have had ZERO problems with burn't wires...including #5! Granted I also quickly changed to a custom firecore set which I speciified specific boots for too which also helped tremendously.
They are still headers though which means a fair amount of monkeying around to get them on and tightened was needed, but in comparison to MY former cheapo mopar performance headers that leaked like a sieve and burn't virtually an entire set of wires per year they are a HUGE improvement.
