Weld in sub frame connectors, best source? #917665
01/30/11 10:40 PM
01/30/11 10:40 PM
Virginia, US
RTDaddy Offline OP
super street
RTDaddy  Offline OP
super street
Virginia, US
I think it was posted the US car Tool weld in connectors were the best. Wher's the beset place to get them? Thanks all.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: Weld in sub frame connectors, best source? [Re: RTDaddy] #917666
01/30/11 11:24 PM
01/30/11 11:24 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Try Mancicni racing. Thats were I got mine.
Re: Weld in sub frame connectors, best source? [Re: NITROUSN] #917667
01/31/11 02:31 AM
01/31/11 02:31 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
USCartool is a MOPARTS sponsor. Click on the page. They fit well and made a huge improvement in overall ride. Feels more like a modern car on washboard streets.
Re: Weld in sub frame connectors, best source? [Re: DennisH ] #917668
02/01/11 10:16 AM
02/01/11 10:16 AM
Jacksonville Florida
elitecustombody Offline
I agree, USCartool connectors, some minor trimming to fit snug up against the floor ,once welded,they look like factory
Re: Weld in sub frame connectors, best source? [Re: elitecustombody] #917669
02/01/11 12:34 PM
02/01/11 12:34 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
Factory specs allowed for up to 1/2 inch of wiggle room in panel placement from the factory, so there is going to be some trimming invovled. Not a fault of the product, but a fault of Chrysler Co.
Re: Weld in sub frame connectors, best source? [Re: elitecustombody] #917670
02/01/11 02:15 PM
02/01/11 02:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Scott Harms is a distributor as well. Good Moparts member! Also, you can reduce trimming and fitting time a bit by using a rubber mallet to gently massage the floor down to close up some of the gaps between the connector and the floor. Don't get carried away or be lazy, but it does help with closing some of the gaps before welding. I welded two sets in so far from under the car and had to use reverse polarity and a stich weld technique to get a nice bead and keep the heat in control. I used a 50-year, paintable, black roof caulk to seal the entire weld, make it look pretty and seal it up prior to undercoating the area with Resto Rick's undercoating and a Shultz gun. It looks factory to the untrained person.
Re: Weld in sub frame connectors, best source? [Re: jbc426] #917671
02/01/11 02:16 PM
02/01/11 02:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The underside.
Re: Weld in sub frame connectors, best source? [Re: jbc426] #917672
02/01/11 02:19 PM
02/01/11 02:19 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
After finishing. They do look better in person.
Re: Weld in sub frame connectors, best source? [Re: jbc426] #917673
02/01/11 02:20 PM
02/01/11 02:20 PM
Scranton, PA
Montclaire Offline
Montclaire  Offline
Scranton, PA
After finishing.
Nice.
Re: Weld in sub frame connectors, best source? [Re: Montclaire] #917674
02/01/11 09:26 PM
02/01/11 09:26 PM
BDW Online content
BDW  Online Content
Very nice
Re: Weld in sub frame connectors, best source? [Re: BDW] #917675
02/01/11 09:57 PM
02/01/11 09:57 PM
Sacramento, Ca
Darius Offline
Darius  Offline
Sacramento, Ca
Very nice work.
I used XV Motorsports connectors on my 70 GTX> They were a great fit and like the US Car Tool ones, required minimal grinding but went in well. here is a pic
Driving modern convenience in classic beauty
