Page 2 of 3 1 2 3
Re: did radio delete cars come with antenna's? [Re: IMGTX] #917592
01/31/11 01:37 AM
01/31/11 01:37 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
'68 Roadrunner here, no radio optioned. No hole in its original fender. BS sheet is blank for radio items. St. Louis car, SPD 9/30/67.
Re: did radio delete cars come with antenna's? [Re: topside] #917593
01/31/11 01:41 AM
01/31/11 01:41 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Just in case anyone is curious - 70/71 dusty Duster fender
Ride eternal, shiny and chrome
Re: did radio delete cars come with antenna's? [Re: DirectSubjection] #917594
01/31/11 01:41 AM
01/31/11 01:41 AM
Here
Here
Re: did radio delete cars come with antenna's? [Re: 68Cbarge] #917595
01/31/11 01:43 AM
01/31/11 01:43 AM
IMGTX Offline
IMGTX  Offline
Dude can you get some good pictures of that plug top, bottom, inside, out, etc? I want to make or get one if possible.
1973 Satellite wagon,Windsor built.
Radio delete,factory plug in fender.
I had seen 1972 models with the same plug when no radio.
Re: did radio delete cars come with antenna's? [Re: 9 Sec Phill] #917596
01/31/11 01:45 AM
01/31/11 01:45 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Assembly plant?
Lynch Road as one example did not code the radio on the tag.
This one is from Newark DE, Plant code 6. This car is a vert if that make a differance.
But you said;
Just wondering, got a 70 RR with antenna but no radio....Thanks all.
No Road Runners from Newark, DE - so now I am confused.
Could the "6" be a G for St. Louis perhaps?
Re: did radio delete cars come with antenna's? [Re: MO_PA] #917597
01/31/11 02:21 AM
01/31/11 02:21 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I worked for a Chrysler Dealer while I was in high school during the mid to late 50's, most or all cars came without an antenna mounted in the fender even if they came with a radio. The antenna with a mounting template was in the trunk of the car. We drilled the fender and mounted the antenna on those new cars. Idea behind it was that cars coming to the dealer with an antenna would be vandalized and the antenna broken off while in transit.
Late 60,s thru mid 70,s they came in like that. Some hack,s used a punch to go thru the firewall for the cable.
Re: did radio delete cars come with antenna's? [Re: earlybee] #917598
01/31/11 02:51 AM
01/31/11 02:51 AM
Alabama
BigMoneyLewis Offline
Alabama
Their would be no reason for the factory to waste parts (and money) by installing an antenna and cable on a car that was not built with a radio.
Perhapes at some point in the cars life , someone has installed a radio (and antenna), perhapes even a dealer installed unit .
Greg
gregward@mchsi.com phone 256-852-0955
Re: did radio delete cars come with antenna's? [Re: BigMoneyLewis] #917599
01/31/11 04:03 AM
01/31/11 04:03 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Maybe somebody replaced the fender at some point. Could have been same color and would you know?
Re: did radio delete cars come with antenna's? [Re: None2Slow] #917600
01/31/11 09:24 AM
01/31/11 09:24 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
My 72 duster has no radio or antennae or hole.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: did radio delete cars come with antenna's? [Re: Rug_Trucker] #917601
01/31/11 09:29 AM
01/31/11 09:29 AM
Baltimore, MD
moparbob71 Offline
moparbob71  Offline
Baltimore, MD
Any NOS fenders I've ever had did not have the hole cut thru.
Re: did radio delete cars come with antenna's? [Re: moparbob71] #917602
01/31/11 10:42 AM
01/31/11 10:42 AM
USA
max Offline
super gas
max  Offline
super gas
USA
This is sorta of a brand "X" story but my parents bought a new 1983 Olds Delta 88 and my father ordered the car with out a radio so he could put his own brand in it.
That car didn't have anything for a radio, the fender wasn't drilled and none of the wiring was in the car or any speakers. Needless to say it was a pain to put a radio in and my mother nearly had a heart attack watching my father drill a hole in the fender for the antenna.
So knowing that 1983 didn't come with anything I could see the older stuff not having it as well.
Re: did radio delete cars come with antenna's? [Re: max] #917603
01/31/11 11:33 AM
01/31/11 11:33 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
i started working in a plymouth dealer body shop in 77 at the age of 14 1/5 so my memory may not be perfect.
when you got a new fender from chrysler almost none of them were drilled for antennas. there were markings on the back of the fender but there were no holes. i have replaced several 68- 70 b body 70-74 E bodies, 68-76 a bodies. some volare fenders started to have holes in them almost all of the horizons. if i remember correctly if you ordered a volare without a antenna there was a plug in the hole. i know horizons without radios had plugs in the hole also.
perception is 90% of reality
Re: did radio delete cars come with antenna's? [Re: Mr T2U] #917604
01/31/11 12:40 PM
01/31/11 12:40 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
I will look at the tag again, it might be a G.
Re: did radio delete cars come with antenna's? [Re: 9 Sec Phill] #917605
01/31/11 01:22 PM
01/31/11 01:22 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
My '73 340 Duster did not have a radio from the factory. The hole in the fender appeared to be original since there was an additional notch to prevent the bezel from spinning. The original paint was still on the car when I bought it in '84 but had an aftermarket antenna mast installed.
So I think all the '73 A-body fenders were stamped regardless of radio or not.
Re: did radio delete cars come with antenna's? [Re: Dave Watt] #917606
01/31/11 01:56 PM
01/31/11 01:56 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
correct me if I'm wrong .did any 66 Coronets come with antenna mounted on pass. side rear quarter ? My 500 had its antenna mounted on the quarter round hole with little notch in it . When I restored the 500, the pass side fender also had a hole with notch but there was a plug that was almost punched out but still connected next to the little notch.
looks like the plug was then leaded in.
Re: did radio delete cars come with antenna's? [Re: mopar_man] #917607
01/31/11 03:24 PM
01/31/11 03:24 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
I have had several NOS antennae package kits and they came with a template to drill the fenders...Barracuda...
Re: did radio delete cars come with antenna's? [Re: mccannix] #917608
01/31/11 03:25 PM
01/31/11 03:25 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Challenger...
On a few original window stickers I have seen from 70-73 A bodies, even if it had a radio, it was not coded there on the window sticker.
I know the b/c sheet and/or fender tag would have it, but why not on the window sticker since it would be an ordered extra cost option to add to the total.
Re: did radio delete cars come with antenna's? [Re: mccannix] #917609
01/31/11 03:36 PM
01/31/11 03:36 PM
I had a '63 Dodge Polara 4 door that didn't come from the factory with a radio and there was no hole in the fender.
Re: did radio delete cars come with antenna's? #917610
01/31/11 04:39 PM
01/31/11 04:39 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I had a 68 Dart GTS that didn't come from the factory with a radio and it had a plug in the fender just like the one on the 73 Satellite fender shown in the picture above.
Re: did radio delete cars come with antenna's? [Re: 6PAX] #917611
01/31/11 07:01 PM
01/31/11 07:01 PM
Canada
sassysixpack1 Offline
Canada
Would a radio delete car have come with a speaker? If not what was used under the dash to close off the speaker hole ?
Page 2 of 3 1 2 3
