Factory option-14" front & 15" rear for real? #917296
01/30/11 04:33 PM
01/30/11 04:33 PM
Canada
demon Offline OP
demon  Offline OP
Canada
A friend of mine had a 70 Super Bee with 14" rallyes on the front and 15" on the rear. It was factory equipped and was even shown on the braking info sheet in the glove box. Saw the paperwork myself. Anyone seen any other Mopars equipped like this?
Edit- I should have said "supposedly" factory equipped !
Re: Factory option-14" front & 15" rear for real [Re: demon] #917297
01/30/11 04:38 PM
01/30/11 04:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
First I've ever heard of that
Re: Factory option-14" front & 15" rear for real [Re: JohnRR] #917298
01/30/11 05:16 PM
01/30/11 05:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Why would the braking sheet show the tire size? Do they normally have tire size? The one I have is not handy.
I wonder if it's a misprint and someone decided to follow it later on.
Re: Factory option-14" front & 15" rear for real [Re: demon] #917299
01/30/11 06:30 PM
01/30/11 06:30 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Gotta call you on that one. Prove it.
Re: Factory option-14" front & 15" rear for real [Re: demon] #917300
01/30/11 06:37 PM
01/30/11 06:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's just,... just crazy
Re: Factory option-14" front & 15" rear for real [Re: DAYCLONA] #917301
01/30/11 06:55 PM
01/30/11 06:55 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Factory option-14" front & 15" rear for real [Re: demon] #917302
01/30/11 07:25 PM
01/30/11 07:25 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Let's think this through....
How would that be coded on the BS? WS? Anyone ever seen a factory reference to this set up?
How would you ever rotate tires? Why would the factory make an owner purchase two different sizes of tires when it was time to replace them? What if the owner couldn't purchase matching tires? Would the owner then be forced to purchase two more matching rims?
What size spare would come with the car 14? 15?
Lots of things to think about on this one....
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Factory option-14" front & 15" rear for real [Re: NITROUSN] #917303
01/30/11 07:41 PM
01/30/11 07:41 PM
Canada
demon Offline OP
demon  Offline OP
Canada
well I could make a call and see if he could scan the paper but I don't know the new owned too well although we have spoken.
When my friend had the car he had to show the brake info sheet to a lot of disbelievers.
Re: Factory option-14" front & 15" rear for real [Re: 69CoronetRT] #917304
01/30/11 07:45 PM
01/30/11 07:45 PM
Canada
demon Offline OP
demon  Offline OP
Canada
AAR Cudas and TA Challengers had different size tires front and rear and so did the 78 Lil Red Express. No spare on the 78 LRT
Re: Factory option-14" front & 15" rear for real [Re: demon] #917305
01/30/11 07:50 PM
01/30/11 07:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed,..tires not rims the brake sheet is obviously a typo
Re: Factory option-14" front & 15" rear for real [Re: demon] #917306
01/30/11 07:59 PM
01/30/11 07:59 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
You must be mistaken in what you thought you saw? Different size tires on an AAR/TA but not different size wheels. In a judged car show, a car with different size wheels from front to back would lose points unless they could show paper work. I'd like to see the Broadcast Sheet or sales order on this one too.
Re: Factory option-14" front & 15" rear for real [Re: DAYCLONA] #917307
01/30/11 08:02 PM
01/30/11 08:02 PM
Canada
demon Offline OP
demon  Offline OP
Canada
It clearly showed 14 inch front wheels and 15 inch rear wheels. I rode and drove the car plenty and went thru all this controversy endless times with him. Real deal as far as I know
Re: Factory option-14" front & 15" rear for real [Re: demon] #917308
01/30/11 08:06 PM
01/30/11 08:06 PM
New Mexico
JMCFAN Offline
JMCFAN  Offline
New Mexico
Re: Factory option-14" front & 15" rear for real [Re: JMCFAN] #917309
01/30/11 09:11 PM
01/30/11 09:11 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I'll guess a typo on the Consumer Information sheet, it does show tire sizes but does not mention rims.
Tire sizes were also noted on the label in the driver's side door jamb. If one exists for this car, what is the part number for it?
The last two digits of the part number for the sticker would be on the broadcast sheet also.
Re: Factory option-14" front & 15" rear for real [Re: Alaskan_TA] #917310
01/30/11 10:33 PM
01/30/11 10:33 PM
CANADA
Desmond Offline
Desmond  Offline
CANADA
Take a look at the pic here. Braking sheets list all the tire sizes for that model and year. Here is one for a '71 Cuda with E60s. But the 14-inch data is there next to it as well. You sure this is not what has you confused?
Re: Factory option-14" front & 15" rear for real [Re: Desmond] #917311
01/30/11 10:48 PM
01/30/11 10:48 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Makes sense - Only 2 tire/rim sizes were available on a 70 Bee....F70-14 and F60-15
Re: Factory option-14" front & 15" rear for real [Re: Desmond] #917312
01/31/11 12:21 AM
01/31/11 12:21 AM
Canada
demon Offline OP
demon  Offline OP
Canada
well since I don't have the sheet available to look at right now I'll just leave it be. I'll see if I can get a copy of it.
I won't rule out the typo possibility.
The whole point of my post was to see if any other cars were built with staggered rim sizes
Re: Factory option-14" front & 15" rear for real [Re: demon] #917313
01/31/11 12:36 AM
01/31/11 12:36 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Poor image I know, but it is of a 1970 Superbee CI sheet. It does show the standard and optional tire sizes.
Re: Factory option-14" front & 15" rear for real [Re: Alaskan_TA] #917314
01/31/11 12:49 AM
01/31/11 12:49 AM
Canada
demon Offline OP
demon  Offline OP
Canada
ok. I should have written my friends car "supposedly" came equipped with the 2 different size rims.
It is possible we all misinterpreted it.
I'll still see if I can find out for sure.
By the way, what does the sheet for the T/A cars show?
Re: Factory option-14" front & 15" rear for real [Re: demon] #917315
01/31/11 12:52 AM
01/31/11 12:52 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
T/A;
