Re: Header modification????????
[Re: Twin Turbo Mower]
#916820
01/30/11 03:25 PM
01/30/11 03:25 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Does not seem much lower then your oil pan inthe pic. What about trying a set of tti's?
And I did kiss that oil pan once too
That's why the new Charlies pan is a little shallower.
Hasn't any tried this and have it work?
[Re: 3ddart]
#916824
01/30/11 08:53 PM
01/30/11 08:53 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
bill: if your going to heat them anyway, jack them into position (even if you need to do it a little at a time) and then apply the heat and when they cool they should stay where you want them. just be ready to remove the jack pressure as they start cooling, so they don't settle higher then anticipated
Heat them slowly in the spots where you want to bend.
I have some Headman fenderwells you could try but I'd have to And the price for new ones is
[Re: Rumblefish68]
#916826
01/31/11 09:40 AM
01/31/11 09:40 AM
WILD BILL
BROOK PARK, OH
Thanks guys. I was thinking a rose bud would be the best tip for this.
Now I need to go out and get one
