PS Box Seal Replacement:: Upper Seal #916545
01/29/11 05:33 PM
01/29/11 05:33 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I am still working with my current ps box and my next issue is to replace the shaft seal on the upper shaft where the steering coupler connects.
Can someone tell me how difficult it is to replace this seal (box mounted in the car) once I have the steering coupler off and out of the way?
I would appreciate any pointers before I start on it.
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916546
01/29/11 09:07 PM
01/29/11 09:07 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I replaced one with the box still in a 64 Belvedere wagon once. I pulled the column out of the way, and it wasn't hard to do. I used a small flat screwdriver to pry the old seal out. Then I packed a little tissue in the opening while I steel wooled the shaft near the seal surface.Tape up the splines so they don't cut the new seal, and remove the tissue and install the seal. I used a socket the drive the new seal with. Good luck.
Re: PS Box Seal Replacement:: Upper Seal [Re: JDMopar] #916547
01/29/11 10:46 PM
01/29/11 10:46 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
That sounds fairly easy but I did not see the seal on the NAPA websight. Hopefully I can find the seal without having to pay for the entire rebuild kit (50$).
Thank you for the reply. I was not sure if it was at the end or if I needed to pull other items out of the end before I got to the seal.
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916548
01/30/11 11:35 AM
01/30/11 11:35 AM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Last time I ck'd ( been a few years though ) the seal was still avail by itself thru Mopar.
Re: PS Box Seal Replacement:: Upper Seal [Re: gtx6970] #916549
01/30/11 01:36 PM
01/30/11 01:36 PM
Eastern,NC
68GTS383 Offline
68GTS383  Offline
Eastern,NC
I just purchased the upper and lower seals for a 68 Dart P/S from Napa
this week.You need a salesman that knows how to look up parts in a book. I think both seals were under 15 bucks!
Re: PS Box Seal Replacement:: Upper Seal [Re: 68GTS383] #916550
01/30/11 03:51 PM
01/30/11 03:51 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I will call my NAPA store and see what they can find. I have already changed the lower seal and maybe this week and can get the steering column out of the way.
I found this kit on the Autozone websight if NAPA can not find it.
Thanks again.
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916551
02/10/11 10:18 AM
02/10/11 10:18 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
""I pulled the column out of the way, and it wasn't hard to do. I used a small flat screwdriver to pry the old seal out. Then I packed a little tissue in the opening while I steel wooled the shaft near the seal surface.Tape up the splines so they don't cut the new seal, and remove the tissue and install the seal. I used a socket the drive the new seal with.""
Thank you for the pointers. It has been a few years since I pulled the wheel assembly.
I now have the seal kit shown above in the last reply. I don't remember if I need to pull the steering coupler apart or not before removing the steering wheel assembly. Could someone clarify?
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916552
02/10/11 05:24 PM
02/10/11 05:24 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
You will either need to pull the coupler apart or remove the coupler from the steering box. My coupler seal and clip were shot, so I pulled the coupler apart. Actually a pretty quick disassembly on my a-body.
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916553
02/10/11 09:34 PM
02/10/11 09:34 PM
JDMopar Offline
JDMopar  Offline
Just drive the roll pin out of the coupler, and take it out with the column. If the coupler needs to be rebuilt, you can do it while you have the whole column out.
Re: PS Box Seal Replacement:: Upper Seal [Re: JDMopar] #916554
02/11/11 08:38 AM
02/11/11 08:38 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Thank you both for the replies. I hope to start on it this weekend.
Re: PS Box Seal Replacement:: Upper Seal [Re: YO7_A66] #916555
02/11/11 04:54 PM
02/11/11 04:54 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
I just picked mine out and knocked a new one in. It was on a 71 Road Runner
Re: PS Box Seal Replacement:: Upper Seal [Re: CYACOP] #916556
02/12/11 06:03 PM
02/12/11 06:03 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I replaced the seal today and everything went smooth. The seal was a pain to dig out but the new one went in fine.
Thanks again for the pointers.
