A body 'cuda body line question #916113
01/28/11 10:29 PM
01/28/11 10:29 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
The body shop got the new 1/4s on my cuda, and we noticed that behind the door there is a large indentation that flares out as it goes back toward the wheel housings. Should this be there? There was so much mud on the old 1/4s that I don't remember if there was this indentation. I want to make sure it's right before they ignore it or pull them out. By the looks of the repop 1/4s, they should be there.
I looked at a few pics and some of them look like the indentations are there and others it looks like they weren't.
Anyone know for sure?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: A body 'cuda body line question [Re: Erik] #916114
01/29/11 01:57 AM
01/29/11 01:57 AM
Va
383S_Fastback Offline
Va
The body line that goes the length of the door (along the lower skin) carries over to the quarter panel and fades out about 8” aft of the door jamb if that is what you are seeing.
'67 & '68 Barracuda FB's
'70 AAR Cuda
'89 Ramcharger 4x4
'06 Ram 2500 CTD 6 spd
...Mopars are always way out back
Between the muddy river and the rusty railroad track
Yeah, the Mopars are always hard to find
But you can always find a few
There’s Cordobas and Furys and Darts and Dusters too
There’s a Diplomat with a Swinger
A new Yorker a Demon and a Scamp
And there’s a 68 Barracuda grill with both headlamps...Slaid Cleaves - Skunk Juice
Re: A body 'cuda body line question [Re: 383S_Fastback] #916115
01/31/11 11:35 AM
01/31/11 11:35 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
It looks more like the upper skin. I'll try to post a pic later.
Re: A body 'cuda body line question [Re: 383S_Fastback] #916116
01/31/11 12:16 PM
01/31/11 12:16 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
and most of the cheep quarters do not have a good line here... also most restored cars do not (people who do not know tend to block it out...)
Usually a good way to tell a good restoration or an orig car...
Re: A body 'cuda body line question [Re: Erik] #916117
01/31/11 12:33 PM
01/31/11 12:33 PM
USA
rftroy Offline
rftroy  Offline
USA
Found a few pictures of my 69 during color sanding. The line in the quarter is subtle, and it wasn't easy to see in the pictures after polishing.
In this picture, the line looks deeper than it really is because of the sanding residue clinging to the edges and increasing the contrast.
Anyway, it shows where the line is so we can know if this is what you are talking about.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: A body 'cuda body line question [Re: rftroy] #916118
01/31/11 01:26 PM
01/31/11 01:26 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
No, I'm not talking about the line on the lower door. I'm talking about the upper portion of the 1/4 right behind the door. On the replacement 1/4s, there seems to be an indentation that slowly flares out as you get toward the wheels. I am wondering if this indentation shoule be there or should it be a smooth line to the wheel wells. If it should be smooth, then I will need to pull the 1/4s out a little in that spot. it has it on both sides which made me wonder if it should be there.
Re: A body 'cuda body line question [Re: Erik] #916119
01/31/11 01:30 PM
01/31/11 01:30 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Check out the 1/4 close ups on this car on ebay. See how the upper portion shows a distortion of the reflection of the road/lines. This makes me think the indentation should be there. It's suttle, but there.
http://cgi.ebay.com/ebaymotors/Plymouth-...5fCarsQ5fTrucks
Re: A body 'cuda body line question [Re: Erik] #916120
01/31/11 02:22 PM
01/31/11 02:22 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
To be honest Erik, I have never noticed if my replacement quarters had that or not. For what it matters, I don't even know if the lower line is there. All I can say is these quarters are the waviest pieces of junk I have ever seen and Goodmark should be embarassed at putting junk like this out.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: A body 'cuda body line question [Re: klunick] #916121
01/31/11 03:14 PM
01/31/11 03:14 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I hear you. But when it's the only thing available........
Re: A body 'cuda body line question [Re: Erik] #916122
01/31/11 08:04 PM
01/31/11 08:04 PM
Russ H. Offline
Russ H.  Offline
Are we talking about the crease that would be about 1 inch above and behind the door handle? If so on my 68 Barracuda that line is a continuation of the upper crease in the door. It fades out about half way back under the quarter window. If need be, I can try posting a picture of it.
Re: A body 'cuda body line question [Re: Russ H.] #916123
01/31/11 08:30 PM
01/31/11 08:30 PM
Russ H. Offline
Russ H.  Offline
is this the line?
Re: A body 'cuda body line question [Re: Russ H.] #916124
01/31/11 08:33 PM
01/31/11 08:33 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
http://www.alaboola.com/lists/Plymouth_Barracuda/1967_Barracuda.php
Do any of these pics show the line you are talking about?
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: A body 'cuda body line question [Re: DCI] #916125
01/31/11 10:51 PM
01/31/11 10:51 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I believe the OP is talking about the inward bulge at the front of the quarter just behind the door.
Yes, they had one, but some are too pronounced and look like a big dent.
Rick
Re: A body 'cuda body line question [Re: RestoRick] #916126
02/01/11 09:08 AM
02/01/11 09:08 AM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
Rick
That is kind of what I was thinking, the beginning of the outward bulge for the rear tire section.
Re: A body 'cuda body line question [Re: RestoRick] #916127
02/01/11 11:48 AM
02/01/11 11:48 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Rick's got it! That is what I am talking about.
Here is a pic, not the best, but if you look at the 1/4 by the door, you will see where the shop sanded off the primer and was about to pull the "dent" out before I stopped them.
Re: A body 'cuda body line question [Re: Erik] #916128
02/01/11 10:50 PM
02/01/11 10:50 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
See the picture link below. That body contour is the reason I avoided that area with my replacement quarter. It was stamped wrong on the reproduction piece. That is absolutely the knottiest replacement quarter panel I have ever had to use.
However, I had no choice.
http://clarkclassic.com/gallery/images/t...rracuda-076.jpg
Steve
www.clarkclassic.com
Re: A body 'cuda body line question [Re: BarrsRestoration] #916129
02/02/11 03:22 PM
02/02/11 03:22 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks for all of the replys. I'll keep my fingers crossed that he will actually finish it this winter so I can have it ready by late spring.
Re: A body 'cuda body line question [Re: Erik] #916130
02/02/11 11:58 PM
02/02/11 11:58 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
It is subtle, mine has it too. I'd more describe it as continuing the contour of the door back about 6-8" or so back into the quarter at which point the quarter starts to bulge out. It's the start of the sexy hump you see when you check the side rear view mirror. The bulge does not begin immediately at the front edge of the panel.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
