Blower/AC pin-out on blower motor switch - Cut Plug! #915760
01/28/11 12:38 PM
01/28/11 12:38 PM
Champaign, Illinois
mopower76 Offline OP
Champaign, Illinois
I need to find out what the proper pin-out is for my Heat-A/C switch is on my 1962 Dodge Dart wagon with a 361 4bbl and A/C.
The previous owner cut the factory plug and ran the A/C-Heat switch to the igniton for hot.
I have a new connector for the switch, and the two (2) wires that are "Hard Wired" to the switch are still there.
I will try to add some pictures of what I am talking about but I have been having problems with the pictures showing up on the postings.
Any help will be appreciated as always, and thanks in advance!
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: mopower76] #915761
01/28/11 01:22 PM
01/28/11 01:22 PM
Andrewh Offline
Andrewh  Offline
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: Andrewh] #915762
01/30/11 04:22 AM
01/30/11 04:22 AM
Champaign, Illinois
Champaign, Illinois
Sorry about that!
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: mopower76] #915763
01/30/11 01:56 PM
01/30/11 01:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Hope you can read it,if not I'll scan it and send it later.
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: 62maxwgn] #915764
01/31/11 12:21 AM
01/31/11 12:21 AM
Champaign, Illinois
Champaign, Illinois
I'm amazed! Where did you find that?! I have a factory service manual and it has nothing on A/C at all.
Thank you so much, I really needed this!!!
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: mopower76] #915765
01/31/11 12:42 AM
01/31/11 12:42 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I know in my FSMs, standard wiring is all in one set and then after the standard stuff is optional stuff. Might be in there, toward the end.
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: Pat_Whalen] #915766
01/31/11 12:50 PM
01/31/11 12:50 PM
Champaign, Illinois
Champaign, Illinois
That worked perfect!
Thanks again!
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: mopower76] #915767
01/31/11 07:07 PM
01/31/11 07:07 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Thanks again!
Here is a scan if the other isn't clear enough.
Re: Blower/AC pin-out on blower motor switch - Cut Plug! [Re: 62maxwgn] #915768
01/31/11 07:11 PM
01/31/11 07:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is where it came from.If you need anything else PM me,it has it all.If you need any A/C parts,I have a lot.
