Blower/AC pin-out on blower motor switch - Cut Plug!
#915760
01/28/11 12:38 PM
01/28/11 12:38 PM
Posts: 61 Champaign, Illinois
mopower76
Champaign, Illinois
I need to find out what the proper pin-out is for my Heat-A/C switch is on my 1962 Dodge Dart wagon with a 361 4bbl and A/C. The previous owner cut the factory plug and ran the A/C-Heat switch to the igniton for hot. I have a new connector for the switch, and the two (2) wires that are "Hard Wired" to the switch are still there. I will try to add some pictures of what I am talking about but I have been having problems with the pictures showing up on the postings. Any help will be appreciated as always, and thanks in advance!
Re: Blower/AC pin-out on blower motor switch - Cut Plug!
[Re: mopower76]
#915761
01/28/11 01:22 PM
01/28/11 01:22 PM
Andrewh
[Re: mopower76]
#915765
01/31/11 12:42 AM
01/31/11 12:42 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
I'm amazed! Where did you find that?! I have a factory service manual and it has nothing on A/C at all. Thank you so much, I really needed this!!!
I know in my FSMs, standard wiring is all in one set and then after the standard stuff is optional stuff. Might be in there, toward the end.
[Re: mopower76]
#915767
01/31/11 07:07 PM
01/31/11 07:07 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
That worked perfect! Thanks again!
Here is a scan if the other isn't clear enough.
