30x10.5x15 Hoosier radial slick #915308
01/27/11 09:08 PM
01/27/11 09:08 PM
Central Coast
P
Plumcrazyracing Offline OP
P
Central Coast
What are your opinions with this tire and the following combination:
Duster
3450 lbs
Low first gear 727
Transbrake
4.11 rear ratio
650 HP
Car has ran a best 1.36 60 ft, 10.08 @ 134, on bias slicks
Re: 30x10.5x15 Hoosier radial slick [Re: Plumcrazyracing] #915309
01/27/11 10:01 PM
01/27/11 10:01 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Start with 24psi and you should pickup about .05-.08 in ET
Re: 30x10.5x15 Hoosier radial slick [Re: nss guy] #915310
01/27/11 10:07 PM
01/27/11 10:07 PM
Saint John
Canuck Offline
super gas
Canuck  Offline
super gas
Saint John
Go for it! I put a set on my Duster....can't wait for the snow to melt to try them!
Re: 30x10.5x15 Hoosier radial slick [Re: Canuck] #915311
01/27/11 10:33 PM
01/27/11 10:33 PM
Me too.I can't wait. I hope I don't blow the tires off.
Re: 30x10.5x15 Hoosier radial slick #915312
01/27/11 11:45 PM
01/27/11 11:45 PM
Washington
SuperStock68Dart Offline
Washington
I run this tire on my Dart SS/JA
I race it at 3490# on a 3470 min
.060 over 383
8" ATI converter
Foot brake with a two step
5.38 gear
1.35 60FT 10.43 @ 126
I use the C06 compound which is softer than C07 and doesn't last as long but will hook a little better. I would start at 18psi and go up a pound each pass until it spins then back off two pounds to be safe! You should pick up a tenth with these tires.
Re: 30x10.5x15 Hoosier radial slick [Re: SuperStock68Dart] #915313
01/28/11 01:02 AM
01/28/11 01:02 AM
Central Coast
P
P
Central Coast
Is the co6 compound the lightweight tire?
Also, if I run these tires on rims that had wheel screws will this be a problem?
Thank you all for your time to respond to this!
Re: 30x10.5x15 Hoosier radial slick [Re: Plumcrazyracing] #915314
01/28/11 02:03 AM
01/28/11 02:03 AM
Washington
Washington
Yes these are the lightweight 18214 radials! It won't be a problem to run them on drilled wheels
Re: 30x10.5x15 Hoosier radial slick [Re: SuperStock68Dart] #915315
01/28/11 10:34 AM
01/28/11 10:34 AM
Hampstead, MD.
Troublemaker427 Offline
Hampstead, MD.
I run them on my car. Usually around 18.5 - 19 psi. My car is just under 3300 lbs. with Cal-Tracs amd mono-leafs. I've been a 1.29 60' and 9.27 foot braking. They work well. Do a light burnout and flip them every 10 runs or so. I usually kill the sidewalls before they wear out. They are also very stable down track, no sway at all and they don't grow which is nice if your wheel opening are tight.
Jody Aberts 1966 Fairlane 427 Troublemaker2 AA/NSS 1964 Galaxie 500XL 390-4spd. 1966 F-100 390-C6 1967 Plymouth VIP 383-TF 2003 Roadking
Re: 30x10.5x15 Hoosier radial slick [Re: Troublemaker427] #915316
01/28/11 10:38 AM
01/28/11 10:38 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
What advantage do they have over the biased ply slicks of the same dimension?
Re: 30x10.5x15 Hoosier radial slick [Re: dc426] #915317
01/28/11 10:40 AM
01/28/11 10:40 AM
Hampstead, MD.
Hampstead, MD.
Less rolling resistance is the big advantage among the others I listed earlier. They are faster.
Re: 30x10.5x15 Hoosier radial slick [Re: Troublemaker427] #915318
01/28/11 02:49 PM
01/28/11 02:49 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We used those radials for a season, found them to be less consistent if traction was an issue, we didn't go any faster in the best conditions either .
Some of the teams over here carry both types of tyres on spare wheels and swap if they need too.
HTH's
