How many years and models used Push Button heat/AC? #915178
01/27/11 01:42 PM
01/27/11 01:42 PM
Champaign, Illinois
mopower76 Offline OP
Champaign, Illinois
I was wondering what years and models Ma' Mopar used the Push Button Vaccuum controlled Heat and A/C moduels like is on my 1962 Dodge Dart 440?
Thanks in advance!
Re: How many years and models used Push Button heat/AC? [Re: mopower76] #915179
01/27/11 02:25 PM
01/27/11 02:25 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
64 used the same unit.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: How many years and models used Push Button heat/AC? [Re: Savoy1964] #915180
01/27/11 04:39 PM
01/27/11 04:39 PM
Champaign, Illinois
Champaign, Illinois
I am assuming 62-64 all models used something similar with the 4 fiber board slides inside that the buttons would use to switch between heat, defrost, cool and off. Right?
Re: How many years and models used Push Button heat/AC? [Re: mopower76] #915181
01/27/11 05:09 PM
01/27/11 05:09 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Yes 62-64 used those buttons for the heater controls. Not sure if 65-66 were the same. The units were white when new turning a yellow collor as they aged. The vacume connections on the back become brittle, usually the main connection to the manafold gets broken first.
Re: How many years and models used Push Button heat/AC? [Re: Savoy1964] #915182
01/27/11 06:29 PM
01/27/11 06:29 PM
Champaign, Illinois
Champaign, Illinois
Thanks for the info!
Re: How many years and models used Push Button heat/AC? [Re: mopower76] #915183
01/27/11 06:43 PM
01/27/11 06:43 PM
Andrewh Offline
Andrewh  Offline
there is a guy on the 62-65 mopar board that fixes them. makes them out of metal instead of plastic.
Re: How many years and models used Push Button heat/AC? [Re: Andrewh] #915184
01/30/11 04:45 AM
01/30/11 04:45 AM
Champaign, Illinois
Champaign, Illinois
Where do I find that board?
Re: How many years and models used Push Button heat/AC? [Re: mopower76] #915185
01/30/11 12:13 PM
01/30/11 12:13 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Here ya go.
web page
Mike
