Ok so what is a good set of headers?? #915127
01/27/11 12:27 PM
01/27/11 12:27 PM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
I am looking at buying a set of headers for my 71 superbee with a 383. I see that there are alot out there I am looking for opions before I pull the trigger on a set. Also I was thinking of finding a used set what do I need to look for to get a good set? Either way I want to ask so I don't buy a junk set.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Ok so what is a good set of headers?? [Re: TX9H6E4CUDA] #915128
01/27/11 12:50 PM
01/27/11 12:50 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Dougs are the best bang for the buck.. Same quality of TTI but $300+ less.
Re: Ok so what is a good set of headers?? [Re: NV69B7RR] #915129
01/27/11 01:15 PM
01/27/11 01:15 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
What exaxctly does a set of Dougs give you that a set of Hookers don't?
Not much to go on, but I get the feeling the OP doesn't need, nor wants to pay for, premium priced headers. Even though they're not as stupid $$$ as TTI's, Dougs aren't cheap. If its a street car with a mildly hopped up 383, the best bang for buck is going to be the Summit brand (now avail. With a ceramic coating). For a 383, a 1-3/4" tube size is perfect.
If bigger and longer tubes are desired for more of a street/strip type of effort, A set of Hooker comps is nearly impossible to beat dollar for dollar.
Whatever you do, stay away from the used set. You'll be buying headers again in a couple of years. (Don't ask how I know)
Re: Ok so what is a good set of headers?? [Re: StealthWedge67] #915130
01/27/11 01:35 PM
01/27/11 01:35 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
You should keep in mind a set that will allow angle plug heads if you ever decide to go that way. I like Doug's, Hooker and TTI.
Re: Ok so what is a good set of headers?? [Re: Cudajon] #915131
01/27/11 05:24 PM
01/27/11 05:24 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
What is a good set of headers????/
Answer: NO SUCH THING !!!!!
Re: Ok so what is a good set of headers?? [Re: mopar_man] #915132
01/27/11 05:34 PM
01/27/11 05:34 PM
md
mopars4ever Offline
mopars4ever  Offline
md
TTI are the best headers I ever owned.
Re: Ok so what is a good set of headers?? [Re: TX9H6E4CUDA] #915133
01/27/11 05:53 PM
01/27/11 05:53 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Used headers? Look for warped flanges that were from overtorquing the header bolts. Excessive rust and cracked welds too.
Personally, TTI's and Doug's are, I'm sure, very nice but I can live with Hookers. I got the 1&7/8" B/RB headers for my 69 Rr, sent them in for ceramic coating, they look great. Hedman makes a decent product too. The trouble with used is the varying opinions on what is "a little rust".
The top-of-the-line headers have 3/8" flanges. I like 16 gauge tubing, race headers are 18 gauge. For a mild-to-tepid 383, 1&3/4" tubing headers will perform great. If you want street/strip or strip only go with the 1&7/8" at a minimum.
Re: Ok so what is a good set of headers?? [Re: mopar_man] #915134
01/27/11 05:57 PM
01/27/11 05:57 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I agree. 69 hi-po logs are hard to beat with 2.5 duals. 500 buck headers better give you 100 hp for that kind of cash and that aint gonna happen unledd you motor is built to take advantage of headers. Plus the burned gaskets, plug wires, trans cables and heat under the hood...Your choice but for that common body style, summit specials can't be much worse performance wise than bucks headers.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Ok so what is a good set of headers?? [Re: TX9H6E4CUDA] #915135
01/27/11 06:04 PM
01/27/11 06:04 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I bought a set of Hooker 2" Super Comp for my '69 Charger R/T. Will never buy them again.
Re: Ok so what is a good set of headers?? [Re: pishta] #915136
01/27/11 06:06 PM
01/27/11 06:06 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What is the price breakdown now? I haven't seen any lists for quite some time. I know the coated Hooker 1 7/8" set on my car is great but I did have to do some work on one tube to get them to fit the 383. 440 was no problem w/ that same set.
Reason I ask is it seems like they were comparable in prce to Doug's, w/ TTI's being more than either.
Re: Ok so what is a good set of headers?? [Re: SomeCarGuy] #915137
01/27/11 06:20 PM
01/27/11 06:20 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Dig deep. TTI's. Dig even deeper for the ceramic polished. Cool under the hood now. Used headers are like used tires. Not for me.
Re: Ok so what is a good set of headers?? [Re: DennisH ] #915138
01/27/11 07:28 PM
01/27/11 07:28 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
check around used ttis come around from time to time i just bought a set from the moparts swap on here . they were very nice and only used one summer .
AS most say don't buy used rusty set of headers,however when looking at the top of the line headers only slightly used and you can pay half of the retail price , idk it make more sence to me to get the high line parts for the same money of a new lower quality part from summit .
1969 Dodge Charger 1969 Dodge Superbee
Re: Ok so what is a good set of headers?? [Re: mopar_man] #915139
01/27/11 08:15 PM
01/27/11 08:15 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Obviously you never have installed a set of Doug's headers
I bought a set of Doug's D452's on my Savoy and they fit and look awesome Perfect finish and nice thick 3/8 thick flanges,work with my angle plug Indy EZ heads,gaskets still good since I bolted them on
Gus
64 Plymouth Savoy
Dana 60
Re: Ok so what is a good set of headers?? [Re: TX9H6E4CUDA] #915140
01/27/11 08:23 PM
01/27/11 08:23 PM
Millinocket, Maine
JonC Offline
JonC  Offline
Millinocket, Maine
TTI's are all I have ever owned (for Mopars), but I can tell you they are probably the only ones I'll ever own. Fit and finish are spot on!! Expensive, relatively. Worth it, absolutely.
Re: Ok so what is a good set of headers?? [Re: JoesMopar] #915141
01/27/11 08:51 PM
01/27/11 08:51 PM
Holly/MI
Holly/MI
Just curious, why?? Don't leave us hangin' here.
Re: Ok so what is a good set of headers?? [Re: Dean_Kuzluzski] #915142
01/27/11 09:35 PM
01/27/11 09:35 PM
GA
Boosted Offline
Boosted  Offline
GA
I have hookers on my 512..Love them and they work great.. 2" to 3 1/2".. these are on my street car...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Ok so what is a good set of headers?? [Re: Dean_Kuzluzski] #915143
01/27/11 09:41 PM
01/27/11 09:41 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
I've used Dougs,hooker and TTI...TTIs seem to go up with the gas prices... ..Each has their own good and bad points...Hooker is a true performance,equal tube header and the super comps are really light...TTIs are made for the fit at the cost of the tuned legnths...Not an issue on a street car though...I wonder what the weight difference is between them all... ...Also any header is going to get tight and might have clearance issues up at the 2 inch primary level but by then you're at the 500hp mark or you would'nt be using them.....Anyhow, I seem to keep going back to the hookers on different applications so I guess I like them best for the price,performance and fit...
Re: Ok so what is a good set of headers?? [Re: fourgearsavoy] #915144
01/27/11 10:41 PM
01/27/11 10:41 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Gus
Obviously , you don't do much street driving with that nice Savoy. Nothing wrong with headers for the strip to gain those few horsepower.
Its just my opinion I don't like headers for the street , just a nuisance !!!I've seen so many sets of headers being removed in my brothers garage in 35 yrs, It just turned me off from them .
BTW , I was using Thorley headers since the early 70s or so when he started working out of his own garage.
YOu have a nice savoy there Gus .
Re: Ok so what is a good set of headers?? [Re: mopar_man] #915145
01/28/11 12:01 PM
01/28/11 12:01 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
I'm running TTI's and the fit was perfect. Not a single modification was required to bolt in place.
Re: Ok so what is a good set of headers?? [Re: mopar_man] #915146
01/28/11 02:03 PM
01/28/11 02:03 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Gus
from all the information i have picked up i have seen that fulllength headers biggest benefit for a streetcar is NOT top end power,its the additional low end torque they make
also good welldesigned headers are not anykind of problem on the street,cheap poorly designed and built headers in combination with beat to death cars are what gives headers a bad reputation
