low budget blown through 318cid turbo build? #914395
01/26/11 04:20 PM
01/26/11 04:20 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi guys.
Before Iam going to boost my R5/P7 in future I`d like to trie make some decent power with our team van 318cid motor and get know better all this turbo stuff. This motor is not long time ago refreshed - new rod and main bearings, new cam bearings, new timing kit, new distributor, new FBO A-688 ignition, new Lunati cam and lifters ( 213/220@.050" , 112 degree lobe, 0.454/0.475 intake/exhaust valve lift, 1000-5500 RPM-s ), new gaskets etc.
Intake is some old Holley Street dominator with 600cfm Holley carb and also I installed headers there ( couple header tubes needed to cut and weld in different angle to fit )
Pistons, rods and crank are stock. No idea about CR, but I belive around 8-8.5
I have no idea what power motor makes right now...maybe some 220-250hp as naturally aspirated, so if I can get 300-350hp out of it with little boost I`l be more than glad. Van drives almost whole year so mainly I`d like to get this motor work well not to get some serious power out of it.
I`d like to hear what you guys suggest, what parts ( what turbo, how much boost, what size BOV etc. )As I live in Europa, I can have Audi,BMW or some Japan car turbo more easely if you are able to suggest something from there
Do my curved distributor and FBO A688 ignition http://www.4secondsflat.com/a688specs.html work with small boost etc.
Transmission is rebuilded TF904 and converter is stock
Thanks a lot!
Georg
Re: low budget blown through 318cid turbo build? [Re: Georg] #914396
01/27/11 06:38 AM
01/27/11 06:38 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
I thought myself to use some bigger diesel motor turbocharger, like( Dodge Ram )Cummins one to avoid excessive heat in motor? I know that its done before
What you guys think? Also what size carb you suggest?
Georg
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: low budget blown through 318cid turbo build? [Re: Georg] #914397
01/27/11 03:07 PM
01/27/11 03:07 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Georg [/quoute]
Good reads here,
http://www.theturboforums.com/smf/index.php?topic=4365.0
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: low budget blown through 318cid turbo build? [Re: CUUDAK] #914398
01/27/11 04:11 PM
01/27/11 04:11 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Visit the Mopar-specific section, too. 29 pages, and unlike this Roots-Procharger-NOS-turbo section, it's turbo-specific.
http://www.theturboforums.com/smf/index.php?board=21.0
Re: low budget blown through 318cid turbo build? [Re: Georg] #914399
01/27/11 04:15 PM
01/27/11 04:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
what i see most use around here is scania turbos from big trucks but they are kind of at a slightly higher powerlevel compared to what you are looking for
Re: low budget blown through 318cid turbo build? [Re: 1Fast340] #914400
01/28/11 05:57 AM
01/28/11 05:57 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
I have Holley 18502 (600cfm) vacuum secondaries carb...would this carb work with plan Iam going to trie make? Or do it need some changes for mild blown-through?
Georg
Re: low budget blown through 318cid turbo build? [Re: Georg] #914401
01/30/11 03:49 PM
01/30/11 03:49 PM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Georg
anyone??
Re: low budget blown through 318cid turbo build? [Re: Georg] #914402
01/31/11 02:24 AM
01/31/11 02:24 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
No will not work. Get a mechanical secondary cark like a 650 or 600.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: low budget blown through 318cid turbo build? [Re: CW25] #914403
02/11/11 01:53 AM
02/11/11 01:53 AM
Minnesota
RockChip Offline
RockChip  Offline
Minnesota
Well im not shure if you have seen my 68 Belvedere post but this is what i have and let me tell ya it really rips for what it is.
(((stock))) 383 280 .480 juce compcam
800 Holley modded myself for blow threw and E85
Torker intake
Mallory dual point locked out at 30*
solid wire core Taylors
NGK no10s
set of 304 stainless shortys with 2.5 pipe connecting together to my turbo
GT45 Y2004K 1.05 A/R Turbo, new from Ebay $300.00, yea I know you have herd of the crap ebay has and you dont want to run it because its all junk but if you get the 1.05 A/R turbo it seems to be the good one.
No intercooler.
Ill Tell ya I have and a few of my friends beat the H*LL out of this thing and have had 0 problems.
A 60mm wastegate also from Ebay 0 problems
A 53mm BOV Ebay working flawless
it will go 20+psi I usually run 13-16 for safety.
the only problem I have had was my mechanical fuel pump couldnt keep up after more than a few test runs.
BG 220 solved the problem, I also ran a bigger line.
1968 Belvedere
727 colum shift with a trans go comp kit
3500 10" stall
3.91 gears
a set of now shot 29/9 Goodyear slicks
Track times to come in 2011
Re: low budget blown through 318cid turbo build? [Re: RockChip] #914404
02/11/11 11:12 AM
02/11/11 11:12 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
thanks guys!
BTW, I have one used Toyota CT26 turbocharger...what you think is it too small to trie?
http://www.mrcontrols.com/primers/turbo.htm
Re: low budget blown through 318cid turbo build? [Re: Georg] #914405
02/12/11 06:29 AM
02/12/11 06:29 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
thanks guys!
Anyone?
Re: low budget blown through 318cid turbo build? [Re: Georg] #914406
02/14/11 05:50 PM
02/14/11 05:50 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Two of them might work but I'd be really concerned with getting exhaust out of that thing.
- Stu Harmon
