Well im not shure if you have seen my 68 Belvedere post but this is what i have and let me tell ya it really rips for what it is.
(((stock))) 383 280 .480 juce compcam
800 Holley modded myself for blow threw and E85
Torker intake
Mallory dual point locked out at 30*
solid wire core Taylors
NGK no10s
set of 304 stainless shortys with 2.5 pipe connecting together to my turbo
GT45 Y2004K 1.05 A/R Turbo, new from Ebay $300.00, yea I know you have herd of the crap ebay has and you dont want to run it because its all junk but if you get the 1.05 A/R turbo it seems to be the good one.
No intercooler.
Ill Tell ya I have and a few of my friends beat the H*LL out of this thing and have had 0 problems.
A 60mm wastegate also from Ebay 0 problems
A 53mm BOV Ebay working flawless
it will go 20+psi I usually run 13-16 for safety.
the only problem I have had was my mechanical fuel pump couldnt keep up after more than a few test runs.
BG 220 solved the problem, I also ran a bigger line.
1968 Belvedere
727 colum shift with a trans go comp kit
3500 10" stall
3.91 gears
a set of now shot 29/9 Goodyear slicks
Track times to come in 2011
