Lunati or Comp hydraulic cam for a 440
#913073
01/24/11 08:32 PM
01/24/11 08:32 PM
BLACKHEMIRR
I'm trying to decide on which cam to buy for a 440-6 restoration, and I'm struggling a little. I've never had a cam failure with Mopar Performance cams and have used quite a few of them, but I'm thinking about going with a Voodoo or Xtreme energy cam this time. The thing that's in the back of my mind is that it seems like a lot of people have said they've had failures with Comp Cams camshafts. Does anyone have an opinion on whether the Lunati cams hold up better these days than the Comp cams do? Does anyone know if there's a difference between these Mopar Performance six pack cams 4529270 & 4529270AB? Thanks
Re: Lunati or Comp hydraulic cam for a 440
[Re: superbyrd]
#913078
01/25/11 11:47 AM
01/25/11 11:47 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd go comp XE275HL or Lunati voodoo 60303 or 60304
[Re: patrick]
#913079
01/25/11 01:32 PM
01/25/11 01:32 PM
Posts: 4,799 ILL
MLR426
ILL
If it is a restoration style build I would go with the 268H and put Brad Penn oil in it. Break in the cam (30w) using varible rpms, change out the oil and filter and logan426
[Re: cjs69mope]
#913082
01/25/11 06:15 PM
01/25/11 06:15 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
If you want the right cam, get with Dwayne Porter......Not Hughes....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
