Lunati or Comp hydraulic cam for a 440 #913073
01/24/11 08:32 PM
01/24/11 08:32 PM
BLACKHEMIRR Offline OP
I'm trying to decide on which cam to buy for a 440-6 restoration, and I'm struggling a little. I've never had a cam failure with Mopar Performance cams and have used quite a few of them, but I'm thinking about going with a Voodoo or Xtreme energy cam this time. The thing that's in the back of my mind is that it seems like a lot of people have said they've had failures with Comp Cams camshafts. Does anyone have an opinion on whether the Lunati cams hold up better these days than the Comp cams do? Does anyone know if there's a difference between these Mopar Performance six pack cams 4529270 & 4529270AB? Thanks
Re: Lunati or Comp hydraulic cam for a 440 [Re: BLACKHEMIRR] #913074
01/24/11 09:10 PM
01/24/11 09:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think I'd go with a Hughes cam if I was going hydraulic.
Re: Lunati or Comp hydraulic cam for a 440 [Re: Stanton] #913075
01/24/11 09:26 PM
01/24/11 09:26 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I guess it depends on your build. if you are just looking for a little more than the factory The Summit 488 cam is a good grind. If you'd like more and want to go up on the gear, add headers and stall One of those other cams or a custom grind would be good. I ran the MP 528 solid w/ a 6-pack and it pulled real nice w/ a 2800 stall and 3.91's
Coming soon!!!!
Re: Lunati or Comp hydraulic cam for a 440 [Re: Mr.Yuck] #913076
01/24/11 09:40 PM
01/24/11 09:40 PM
It's being restored back to pretty much stone stock 10.5:1 4-speed with 3.54 gears and manifolds. If I went with more cam than original, it's not going to be a lot bigger.
Re: Lunati or Comp hydraulic cam for a 440 [Re: BLACKHEMIRR] #913077
01/24/11 10:46 PM
01/24/11 10:46 PM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
comp XE268. you will love it. my
Re: Lunati or Comp hydraulic cam for a 440 [Re: superbyrd] #913078
01/25/11 11:47 AM
01/25/11 11:47 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd go comp XE275HL or Lunati voodoo 60303 or 60304
2017 Grand Cherokee Overland
Re: Lunati or Comp hydraulic cam for a 440 [Re: patrick] #913079
01/25/11 01:32 PM
01/25/11 01:32 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
If it is a restoration style build I would go with the 268H and put Brad Penn oil in it.
Break in the cam (30w) using varible rpms, change out the oil and filter and
logan426
Re: Lunati or Comp hydraulic cam for a 440 [Re: MLR426] #913080
01/25/11 01:56 PM
01/25/11 01:56 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I used a Crower cam in my 440/6 ( I think its 32242 )and I use stock rockers and a lil better spring. It has 222@.050 and 234 @.050 duration and .486/.495 lift . A great cam with a ton of power and good with stock manifolds due to its wider 112 lsa. Another great cam I used on a friends sixpack car is the Mr Sixpack cam. BTW ,do you really have 10.5 compression ??? I think you would have to deck the block and mill a bit off the heads and use a steel shim (oem)head gasket to get it that high. My sixpack block had the oem pistons about .020 down .
Re: Lunati or Comp hydraulic cam for a 440 [Re: THESHAKERPROJECT] #913081
01/25/11 05:57 PM
01/25/11 05:57 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
Make sure of compression first you will be glad you did !
1969 Dodge Charger 1969 Dodge Superbee
Re: Lunati or Comp hydraulic cam for a 440 [Re: cjs69mope] #913082
01/25/11 06:15 PM
01/25/11 06:15 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
If you want the right cam, get with Dwayne Porter......Not Hughes....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Lunati or Comp hydraulic cam for a 440 [Re: Von] #913083
01/25/11 07:08 PM
01/25/11 07:08 PM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
I put in new Comp XE268, Comp lifters and Comp adjustable rockers- The Comp lifters were junk out the box, the tolerances were too tight in the lifter bores and the plungers stuck on 3 of them and ruined 3 pushrods and the adjustors on top of the rockers. When I called Comp their customer service guy was a flaming condescending ***hole- said the only way it could have done it was by me racing during the break-in period and floated the valves , wouldn't stand behind their stuff at all...I ended up running Rhoades lifters, and learned you can change out a complete set of lifters by snaking them out the distributor hole with a magnet- without pulling the intake
