Billet Servos 727(update) WITH PICS #913037
01/24/11 08:04 PM
01/24/11 08:04 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Is it worth putting them in?
I have the kit from my brothers trans just thinking about doing it.
Re: Billet Servos 727 [Re: Scamp408] #913038
01/24/11 08:09 PM
01/24/11 08:09 PM
organ
maximum entropy Offline
organ
piece of mind if you're running high line pressure. i have billet in mine. the front servo seals better with the improved o ring arrangement also.
Re: Billet Servos 727 [Re: maximum entropy] #913039
01/24/11 08:16 PM
01/24/11 08:16 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
x2 ... on a high-pressure application. But on a foot-brake(no trans brake) combo ....save your money.
Re: Billet Servos 727 [Re: dOoC] #913040
01/24/11 08:20 PM
01/24/11 08:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
In the 518 its plastic so I went with billet alum
Re: Billet Servos 727 [Re: MR_P_BODY] #913041
01/24/11 08:25 PM
01/24/11 08:25 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I foot brake manual vb. I already have the parts (from brother)and while I had the car in the air I was thinking about doing it.
Re: Billet Servos 727 [Re: Scamp408] #913042
01/24/11 08:29 PM
01/24/11 08:29 PM
organ
organ
manual vb, i'd do it. it'll just be a matter of time before it cracks the rear servo.
Re: Billet Servos 727 [Re: maximum entropy] #913043
01/24/11 08:34 PM
01/24/11 08:34 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I just grab the kit from the garage I have both frt and rear servos. The more I inspect it seems I am missing the seal on the low/rev one.I guess my brother lost that.
Re: Billet Servos 727 [Re: Scamp408] #913044
01/24/11 10:35 PM
01/24/11 10:35 PM
NC
440Jim Offline
440Jim  Offline
NC
My 2-cents:
1) If you have a low band apply valve body, the rear billet servo is a good idea as it can crack.
Even without the billet rear servo, shimming the stock servo to be solid is helpful; just be careful putting it in reverse (go to idle).
2) The front servo from the pre-'71 trans is a better race part. So, putting an aftermarket pre-'71 style is a good upgrade. If you have a pre-'71, dual spring, non-load servo, it is fine.
Re: Billet Servos 727 [Re: 440Jim] #913045
01/25/11 11:51 AM
01/25/11 11:51 AM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
They are worth the expense for more than one reason.
The aftermarket front servos uasually have an o-ring seal in the cover for the band actuation shaft. This helps minimize leaks due to old worn out covers and maintain direct clutch pressure.
Obviously the strength is another benifit.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Billet Servos 727 [Re: turbobitt] #913046
01/25/11 02:30 PM
01/25/11 02:30 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Don't mean to hijack the OP but what are the simptoms when you have a bad, cracked servo or the sealing rings go bad?
I'm just not a trans guy
Re: Billet Servos 727 [Re: roadhazard] #913047
01/25/11 02:37 PM
01/25/11 02:37 PM
organ
organ
ime, the low reverse servo cracks or breaks first, and you get delayed reverse engagement, or no reverse. intermediate servo failure would cause loss of second gear. when my rear servo cracked, i didn't wait for more problems, i replaced both servos.
Re: Billet Servos 727 [Re: maximum entropy] #913048
01/25/11 09:55 PM
01/25/11 09:55 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I would like to thank mrrandyj he took care of me on the seal.If you need billet servos give him a call he went out of his way for me and was very fast to help out.
Re: Billet Servos 727 [Re: Scamp408] #913049
01/26/11 06:57 PM
01/26/11 06:57 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Good thing I decided to do this.I took the pan off today and was poking around and what did I come to find the steel spring holder was bent on the low/rev piston.If I left it I think it would blow out good news is the pan and filter look clean just the normal crud.
Re: Billet Servos 727 [Re: Scamp408] #913050
01/26/11 07:25 PM
01/26/11 07:25 PM
organ
organ
Re: Billet Servos 727 [Re: Scamp408] #913051
01/26/11 08:45 PM
01/26/11 08:45 PM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
If I am not mistaking I think my rear billet servo came with a HD retainer...
Re: Billet Servos 727 [Re: 74_360_Cuda] #913052
01/26/11 10:41 PM
01/26/11 10:41 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Randy's the best. Doesnt surprise me in the least.
Re: Billet Servos 727 [Re: dOoC] #913053
01/26/11 11:46 PM
01/26/11 11:46 PM
Fairview Tennessee
SV_MOPARS Offline
SV_MOPARS  Offline
Fairview Tennessee
you forgot traffic signature, i live my life here being held hostage by traffic, do yourself a favor where ever your at stay there, you are much better off! trust me.
Re: Billet Servos 727 [Re: SV_MOPARS] #913054
01/27/11 08:29 PM
01/27/11 08:29 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Got it apart today and the retainer is all bent also the old servo piston has the spring installed and no spacer to make it solid.Befor i had the trans built I did a shift kit and installed the spacer i guess the trans shop changed it. What do you guys think why would you leave it in the stk configuration?
Re: Billet Servos 727 [Re: Scamp408] #913055
01/28/11 08:10 AM
01/28/11 08:10 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Which spring should I use ? the one on the right is what came out and the left is the new one but it looks canted.
Re: Billet Servos 727 [Re: Scamp408] #913056
01/28/11 11:54 AM
01/28/11 11:54 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Use the new one , the cant shouldn't be an issue as it is compressed when installed.
