Billet Servos 727(update) WITH PICS
#913037
01/24/11 08:04 PM
01/24/11 08:04 PM
Posts: 2,709 NJ central
Scamp408
NJ central
Is it worth putting them in? I have the kit from my brothers trans just thinking about doing it.
Re: Billet Servos 727
[Re: Scamp408]
#913038
01/24/11 08:09 PM
01/24/11 08:09 PM
Posts: 5,080 organ
maximum entropy
organ
piece of mind if you're running high line pressure. i have billet in mine. the front servo seals better with the improved o ring arrangement also.
[Re: dOc !]
#913040
01/24/11 08:20 PM
01/24/11 08:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
x2 ... on a high-pressure application. But on a foot-brake(no trans brake) combo ....save your money.
In the 518 its plastic so I went with billet alum
[Re: Scamp408]
#913042
01/24/11 08:29 PM
01/24/11 08:29 PM
Posts: 5,080 organ
maximum entropy
organ
manual vb, i'd do it. it'll just be a matter of time before it cracks the rear servo.
[Re: 440Jim]
#913045
01/25/11 11:51 AM
01/25/11 11:51 AM
Posts: 761 Southington Ct.
turbobitt
Southington Ct.
They are worth the expense for more than one reason.
The aftermarket front servos uasually have an o-ring seal in the cover for the band actuation shaft. This helps minimize leaks due to old worn out covers and maintain direct clutch pressure. Obviously the strength is another benifit.
Allan G.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: Scamp408]
#913051
01/26/11 08:45 PM
01/26/11 08:45 PM
Posts: 387 Montreal PQ, Canada
74_360_Cuda
Montreal PQ, Canada
Good thing I decided to do this.I took the pan off today and was poking around and what did I come to find the steel spring holder was bent on the low/rev piston.If I left it I think it would blow out good news is the pan and filter look clean just the normal crud.
If I am not mistaking I think my rear billet servo came with a HD retainer...
[Re: 74_360_Cuda]
#913052
01/26/11 10:41 PM
01/26/11 10:41 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Randy's the best. Doesnt surprise me in the least.
[Re: dOc !]
#913053
01/26/11 11:46 PM
01/26/11 11:46 PM
Posts: 1,236 Fairview Tennessee
SV_MOPARS
Fairview Tennessee
you forgot traffic signature, i live my life here being held hostage by traffic, do yourself a favor where ever your at stay there, you are much better off! trust me.
[Re: SV_MOPARS]
#913054
01/27/11 08:29 PM
01/27/11 08:29 PM
Scamp408
NJ central
Got it apart today and the retainer is all bent also the old servo piston has the spring installed and no spacer to make it solid.Befor i had the trans built I did a shift kit and installed the spacer i guess the trans shop changed it. What do you guys think why would you leave it in the stk configuration?
[Re: Scamp408]
#913056
01/28/11 11:54 AM
01/28/11 11:54 AM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Which spring should I use ? the one on the right is what came out and the left is the new one but it looks canted.
Use the new one , the cant shouldn't be an issue as it is compressed when installed.
