Ring & Pinion Quality Question #913014
01/24/11 06:38 PM
01/24/11 06:38 PM
Georgetown Ontario Canada
anlauto Offline OP
anlauto  Offline OP
Has anybody used these Motive Performance Ring and Pinion sets ? http://cgi.ebay.com/ebaymotors/ws/eBayIS...RK%3AMEWAX%3AIT They seem pretty cheap (I mean affordable )
CHECK OUT MY NEW WEB SITE !
Re: Ring & Pinion Quality Question [Re: anlauto] #913015
01/24/11 06:41 PM
01/24/11 06:41 PM
ky.
K
kenworth_goose Offline
K
ky.
That what I have in my 1 ton dually dana 70. I went from a 4.56 to the 3.54's. It's a work truck and has had many 15k loads behind it and not 1 issue in over 4 years.
Re: Ring & Pinion Quality Question [Re: anlauto] #913016
01/24/11 06:57 PM
01/24/11 06:57 PM
That MIGHT be the same brand Randys sells & they state up front that they are not quiet running but in a circle track (for me) it's a non issue, street would be a different story. HOW noisy they are I do not know
Re: Ring & Pinion Quality Question [Re: RapidRobert] #913017
01/24/11 08:50 PM
01/24/11 08:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You might be surprised how many reputable gear sellers offer repackaged Motived Gears.
Randy's in-house brands are supposedly made in India.
Re: Ring & Pinion Quality Question [Re: John_Kunkel] #913018
01/24/11 09:32 PM
01/24/11 09:32 PM
anlauto Offline OP
anlauto  Offline OP
Are they any good for a casual cruiser...no drag racing or high mileage?
If set up correctly will they be quite?
Re: Ring & Pinion Quality Question [Re: anlauto] #913019
01/24/11 10:28 PM
01/24/11 10:28 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Might I suggest you direct these questions to Dr Diff here.
Master, again and still
Re: Ring & Pinion Quality Question [Re: anlauto] #913020
01/24/11 10:52 PM
01/24/11 10:52 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
I work in a Driveline Shop in PA. www.GreensburgMachine.com, We set up about 300 Car and Truck Differentials a Year,
We use some Motive Gears, But when we do its always the Motive Performance, They do a another laping process to Make them Quiter over the regular Motive. We have ok luck with them in a 8 3/4s. But in some other types of rears they can be noisey, The 9 1/4 is one, Strength wise, They are Not too bad.. I Do prefer, OEM Gears 1st, Then US Gear or Strange over the Motive Performance, depending on Ratio and availability.. Bottom Line.. If You Go with the Motive Performace and they are set up right. You will be just fine
Re: Ring & Pinion Quality Question [Re: DaveRS23] #913021
01/24/11 11:05 PM
01/24/11 11:05 PM
anlauto Offline OP
anlauto  Offline OP
I didn't realize he is on here. I hang out mostly on the restoration side of things.
Also the opinion of the person selling the parts may differ from the opinion of people buying and using the parts. No offence intended
Re: Ring & Pinion Quality Question [Re: anlauto] #913022
01/24/11 11:35 PM
01/24/11 11:35 PM
Amherst,NY
challengermike Offline
Amherst,NY
As mentined above motive offers gears for different setups.stock/performance.And i also agree that the 9 1/4 ones are noisey(pretty much any brand)except oem ones.
Re: Ring & Pinion Quality Question [Re: anlauto] #913023
01/25/11 09:41 PM
01/25/11 09:41 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Not to come off like a commercial for the guy, but Dr Diff probably installs more gear sets than he ships. And is a straight shooter.
Re: Ring & Pinion Quality Question [Re: kenworth_goose] #913024
01/26/11 05:47 PM
01/26/11 05:47 PM
anlauto Offline OP
anlauto  Offline OP
Talked to Cass on the phone, very helpful. Bought the gears and a couple of bearing sets...Gave me a great deal on shipping and shipped them lightening fast !
