383 head dumb question time #913003
01/24/11 06:29 PM
01/24/11 06:29 PM
TX
RogersFury Offline OP
TX
Starting a rebuild of a 65 Fury Convertable with a 383B engine. But I've got a question about the heads. There's two intake ports on each end, but there's a hole in the head in the middle that doesn't match the intake. Is there supposed to be some seal over it, etc?
Re: 383 head dumb question time [Re: RogersFury] #913004
01/24/11 06:31 PM
01/24/11 06:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is a port to allow heat to escape from the hot exh passage that runs thru the intake , it's supposed to be open and exposed .
Re: 383 head dumb question time [Re: JohnRR] #913005
01/24/11 06:45 PM
01/24/11 06:45 PM
TX
TX
Thanks. I've just never seen that on a head before, and with the issues we've had with this resto (got someone else's project), especially the engine, just had to ask.
Re: 383 head dumb question time [Re: RogersFury] #913006
01/24/11 08:29 PM
01/24/11 08:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
It's typical of factory cast iron mopar wedge heads, both big and small block.
