Page 14 of 16 1 2 12 13 14 15 16
Re: 430" small block build [Re: MR_P_BODY] #912882
07/24/12 03:35 PM
07/24/12 03:35 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
ok - i was not sure what engine you were referring to.
I'll race ya - I got a head start, but you work quicker.
Re: 430" small block build [Re: DJVCuda] #912883
07/24/12 04:30 PM
07/24/12 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah this is the engine in the Rampage... maybe I should
have worked slower and I wouldnt be where I am..
should have looked the carb over... oh well... its
only money... spend it like you have it...lol
Re: 430" small block build [Re: MR_P_BODY] #912884
07/24/12 05:40 PM
07/24/12 05:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mr P, I know you built your headers fro the Rampage. What size are they?
Re: 430" small block build [Re: justinp61] #912885
07/24/12 05:54 PM
07/24/12 05:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
1 7/8" I dont have the lengths off hand but I believe
they are 32" long with a 3 1/2" collector about 18" long...
then I went with 3" exhaust all the way back to
the bumper
Re: 430" small block build [Re: DJVCuda] #912886
07/24/12 11:51 PM
07/24/12 11:51 PM
BPE Offline
BPE  Offline
How about some flow numbers on all 3 heads? And don't show us some gay graph, we just want to see the numbers.
Rod
Re: 430" small block build [Re: BPE] #912887
07/25/12 12:06 AM
07/25/12 12:06 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Rod
That's a great idea,especially since you are changing the whole combination. Hard to tell what changes are resulting in the increases
Keith
Re: 430" small block build [Re: Dunnuck Racing] #912888
07/25/12 12:26 AM
07/25/12 12:26 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
actually if you have the gay graph post that too...im a visual person...lol...
cheapst..
actually i just read that and it sounds terrible..
i like to see graphs cause they eliminate correction factors and show a decent corrilation to the power graph after dyno-ing..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: 430" small block build [Re: BPE] #912889
07/25/12 08:40 AM
07/25/12 08:40 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Rod
gay graph as requested
please keep in mind this was all done on the bench at Fonses - it seems to be a little stingy from the advertised numbers, but since they were all done on the same bench I can get a good idea on how things look side by side.
exhaust
intake
Re: 430" small block build [Re: DJVCuda] #912890
07/25/12 10:55 AM
07/25/12 10:55 AM
Northern Indiana
Northern Indiana
Nice chart ,
Thanks for sharing.
Keith
Re: 430" small block build [Re: Dunnuck Racing] #912891
07/25/12 11:01 AM
07/25/12 11:01 AM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Re: 430" small block build [Re: Dunnuck Racing] #912892
07/25/12 11:08 AM
07/25/12 11:08 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
After you guys are seating the rings do you take compression and leak down to get a base for future testing?
Re: 430" small block build [Re: emarine01] #912893
07/25/12 04:40 PM
07/25/12 04:40 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
best pull of today -
627 hp @6500
560 ft/lbs at 5000
34 deg timing
88/90's in the 1000 hp holley
1 3/4 to 1 7/8 step headers
Re: 430" small block build [Re: DJVCuda] #912894
07/25/12 04:46 PM
07/25/12 04:46 PM
Renton Washington
Triple Threat Offline
Renton Washington
She's making good power now
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 430" small block build [Re: Triple Threat] #912895
07/25/12 04:47 PM
07/25/12 04:47 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
nuthin like 430 cubes at 7 grand!!!
Re: 430" small block build [Re: DJVCuda] #912896
07/25/12 07:28 PM
07/25/12 07:28 PM
BPE Offline
BPE  Offline
Who ported the intakes?
Rod
Re: 430" small block build [Re: BPE] #912897
07/25/12 08:27 PM
07/25/12 08:27 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Is the super vic ported? That pup is makin some power with conservative flow #s and cam
Re: 430" small block build [Re: emarine01] #912898
07/25/12 10:14 PM
07/25/12 10:14 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
I gasket matched the intake, and also opened up the flange since it had that goofy overlap into it.
All the numbers were low - I'm not sure what caused that but they were all consistently low. The flow sheet from the MCH's add another 10-15 cfm in there and that is from his bench - I believe the test numbers were at 24" on the bench at the shop, but cant confirm that right now. but we did go into this knowing the numbers were low. I figure that since they are all from the same bench you can get a gauge as to how each stacks up against the other under the same conditions.
we had fun today finding hp - started out at 580@ 6500 - was way lean - needed to jet up ( was at 82 & 86 ) and timing was at 30 ( where the other 2 heads liked it AFR was in the high 13's and low 14's - -
next pull had jetted up to 84 & 88 - made 609 @ 6500 - still was lean - about 13.8:1 - gettin there!
Last run of the day was 34 degrees timing and 88's and 90's - thats when we hit 12.5 afr and 627 @6500
Re: 430" small block build [Re: DJVCuda] #912899
07/25/12 10:29 PM
07/25/12 10:29 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
627 hp @6500
560 ft/lbs at 5000
34 deg timing
Wow...very impressive Dave!
It would be interesting to see the dyno curves overlayed for the 3 combos...cuz I'm a visual person and I like gay graphs
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: 430" small block build [Re: OUTLAWD] #912900
07/25/12 10:33 PM
07/25/12 10:33 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
lol
i'll try to get it together tomorrow
Re: 430" small block build [Re: MR_P_BODY] #912901
07/25/12 11:29 PM
07/25/12 11:29 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
108 LSA + 4
288/292 @ .020" Duration
258/262 @ .050" Duration
181/185 @ .200" Duration
.426"/.430" Lobe lift
.639"/.645" Advertised Lift with 1.5:1 rockers
My cam is similar but with a couple differences..
mine is 105 lsa installed at 105(didnt want the added
torque with advancing it to increase the stall point)
the lift is the same but I have a few more degrees
on the exhaust side... same on the intake... with
basically the same compression.... I know your gonna
have more torque due to the stroke over my set up
similar to my cam too 254/262@050 .200 179 /184 cam lift 430/420 on 107 with 11.2 comp pulls like train with the indys , people over cam there engines some times these size cams are great street/strip cam
well done with the build with great info and graphs ,you will love going down the strip with that combo
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
