Re: 430" small block build
[Re: OUTLAWD]
#912862
07/21/12 09:02 PM
07/21/12 09:02 PM
Posts: 458 Michigan
BPE
I don't know all the details, so I will let Dave tell the story, but I do know what it made today before the wussy had to go to a birthday party . Rod
[Re: meus31]
#912867
07/22/12 09:55 AM
07/22/12 09:55 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
more cam and bigger headers
actually thats exactly whats up next
[Re: emarine01]
#912871
07/22/12 10:04 PM
07/22/12 10:04 PM
DJVCuda
Atco NJ
Too bad ya dont have a super vic to test, Thanks for the post its been good from the start
super victor is part of the recipe for the next test
[Re: DJVCuda]
#912873
07/24/12 11:38 AM
07/24/12 11:38 AM
DJVCuda
Atco NJ
out with the old: In with the new: MCH CNC heads - 2.055 in / 1.60 ex COMP Solid roller - Dur 258/262, Lift .639/645 w/ 1.5's Ported Eddy Super Victor intake 1000 hp Holley Going for a 1 3/4 to 1 7/8 step header as well to test ( paint looks red in my pix, but it's orange )
[Re: DJVCuda]
#912874
07/24/12 12:12 PM
07/24/12 12:12 PM
Triple Threat
Renton Washington
I have the same pan on my engine. How much oil are you running?
Any why the switch between SDSS ported heads and the MCH CNC'd heads? Kind of adds another variable to the equation.
[Re: DJVCuda]
#912875
07/24/12 12:18 PM
07/24/12 12:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
out with the old:
In with the new:
I'm going to be curious of this next set up... much closer to my set up.... got the total specs on the cam like LSA..... with the header change I think its gonna really start to show some numbers.... good luck
[Re: MR_P_BODY]
#912877
07/24/12 12:33 PM
07/24/12 12:33 PM
DJVCuda
Atco NJ
I flow tested all 3 heads that will be run on the motor - the MCH's flow the best. as well as more port volume. low lift ( and average cfm ) was a significant increase with the Modern's Running 6.5 qts
i'm hoping the paint job alone will get me to 600 - lol
The 600 hp mark is what I am after at this point -
cam : 108 LSA + 4
288/292 @ .020" Duration 258/262 @ .050" Duration 181/185 @ .200" Duration .426"/.430" Lobe lift .639"/.645" Advertised Lift with 1.5:1 rockers
[Re: justinp61]
#912878
07/24/12 12:34 PM
07/24/12 12:34 PM
DJVCuda
Atco NJ
How much compression does it have now? It would've been great to see the other combo with a different set of headers. Maybe you could run both sets on this configuration for a A to B comparison.
I plant to test a set of 1 3/4 to 1 7/8 steps now that I got them
we are a hair under 11:1 with the CC's of these heads. I think it's 10.75:1 to be exact, but i cant remember off the top of my head.
[Re: DJVCuda]
#912879
07/24/12 12:55 PM
07/24/12 12:55 PM
MR_P_BODY
108 LSA + 4 288/292 @ .020" Duration 258/262 @ .050" Duration 181/185 @ .200" Duration .426"/.430" Lobe lift .639"/.645" Advertised Lift with 1.5:1 rockers
My cam is similar but with a couple differences.. mine is 105 lsa installed at 105(didnt want the added torque with advancing it to increase the stall point) the lift is the same but I have a few more degrees on the exhaust side... same on the intake... with basically the same compression.... I know your gonna have more torque due to the stroke over my set up
[Re: DJVCuda]
#912881
07/24/12 03:16 PM
07/24/12 03:16 PM
MR_P_BODY
What were your numbers?
Dont know yet... I first put the engine in the car without any dyno time but had oil issues... this time I'm going on the dyno so that SHOULD be in about 10 days I figure... waiting on the new rings right now
