Page 2 of 16 1 2 3 4 15 16
Re: 430" small block build [Re: Overdrive440] #912642
01/24/11 10:20 PM
01/24/11 10:20 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
the heads will be a progression through Eddy heads. Ryan J will be working some magic on a set.
Re: 430" small block build [Re: Dunnuck Racing] #912643
01/24/11 10:25 PM
01/24/11 10:25 PM
Az
Crizila Offline
Crizila  Offline
Az
Please keep us updated.I am looking forward to your results.
Keith
Looks like an awesome rotating assembly. Be interested to see how much block clearancing will be needed for that stroke.
Fastest 300
Re: 430" small block build [Re: DJVCuda] #912644
01/24/11 10:29 PM
01/24/11 10:29 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
will this be ready for the rental u guys do every year? and also best of luck with it
Re: 430" small block build [Re: fishy340] #912645
01/24/11 10:31 PM
01/24/11 10:31 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
With the 2" journal - less then a 4" stroke with a stock mopar journal
the motor better be - the car - not a chance...
Re: 430" small block build [Re: fishy340] #912646
01/24/11 10:31 PM
01/24/11 10:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I hope that 4 bolt caps are in the plans
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 430" small block build [Re: dusturbd340W5] #912647
01/24/11 10:39 PM
01/24/11 10:39 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Pro-Gram's will should be fitted in a few weeks.
Re: 430" small block build [Re: DJVCuda] #912648
01/24/11 11:02 PM
01/24/11 11:02 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Nice Dave. This is pretty much my plan for this year. I have a 69 340 block, but I'd much rather find a tall deck 48 degree R3 block. Keep the pics and info coming.
Re: 430" small block build [Re: Devilbrad] #912649
01/24/11 11:40 PM
01/24/11 11:40 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I bought a R block last year to build a Big Inch small block, but after talking to RyanJ on what I had. At this point I will be going with a stock block build. Since I have a 9.20" 59 degree 48 babbit cam tunnel block with a 3.990 hone finish bore.
What happened with that R3 block was Mopar line bored the cam tunnel in those 59* Siamese bore 9.20" R3's accidentally oversize to the 48 degree dimension.... the problem with that is no camshaft core ever existed for a 1.998" journal on all 5 cam journals AND 59 degree lobe spacing & bank angle. Basically what I'm telling you is there is no camshaft you can buy to install in your bock.
Switched to the dark side...
Re: 430" small block build [Re: JSR1485] #912650
01/24/11 11:46 PM
01/24/11 11:46 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
nice build, Rods cranks are nice peices
Re: 430" small block build [Re: JSR1485] #912651
01/25/11 07:55 AM
01/25/11 07:55 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Where did you get that block? I think I saw that one .
Re: 430" small block build [Re: Scamp408] #912652
01/25/11 09:11 AM
01/25/11 09:11 AM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
I bought it from a member on here.
Re: 430" small block build [Re: JSR1485] #912653
01/25/11 09:51 AM
01/25/11 09:51 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Would you mind listing the cost of parts and labor??
Re: 430" small block build [Re: ThermoQuad] #912654
01/25/11 10:44 AM
01/25/11 10:44 AM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
The only thing i dont like is that much stroke,after taking a buddys 445 sbf apart you can see the small end on the rod bushing was getting bet to death[you can see by eye how bad one side is wore ]to much side loading. he is going back to a 4 inch stroke
Re: 430" small block build [Re: fasthawk6] #912655
01/25/11 10:54 AM
01/25/11 10:54 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Re: 430" small block build [Re: POS Dakota] #912656
01/25/11 12:32 PM
01/25/11 12:32 PM
Atco NJ
DJVCuda Offline OP
DJVCuda  Offline OP
Atco NJ
Re: 430" small block build [Re: fasthawk6] #912657
01/25/11 12:38 PM
01/25/11 12:38 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
What stroke and rod length was on this engine? Forced induction? More details please.
Re: 430" small block build [Re: DJVCuda] #912658
01/25/11 12:38 PM
01/25/11 12:38 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Re: 430" small block build [Re: POS Dakota] #912659
01/25/11 01:03 PM
01/25/11 01:03 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Well so much for ford junk, thought this was about small block mopars.
Ive several strokers from 410s to a hair over 450 inches, have not noticed any rods issues on inspection and they often see over 7k.
More and more we will see the 4 plus stroke cranks as common as the 4 inchers.
40Ford can fill folks in on what an X block will take or just read some of his postings, its pretty clear you can knock the sides out of anything if you try hard enough.
But other then some cast crank posts I dont see many small blocks, oem or afterm, X R with there guts spit out as we do so many stock block BB motors.
Dont see how a small block ford plays into this, the small block stroker has proven itself as a good solid combo. And im sure Dave knows the right people to get it done.
Re: 430" small block build [Re: quick77rt ] #912660
01/25/11 01:21 PM
01/25/11 01:21 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Ok, What about excessive bore wear? Piston life? Rings?
There are a few of us sitting on r blocks who would like to build a nice stout street/strip engine that will last a while with a 4.25 inch stroke or maybe larger...without having to be torn down every winter. Daily driver duty...
But until now, it's very hard to get any kind of take on what the life expectancy would be in general compared to say a simple 4 incher.
It's hard to make a decision without getting the facts.
I know these things vary greatly, but is there any kind of general rule of thumb here? What to expect?
Insight?
Re: 430" small block build [Re: POS Dakota] #912661
01/25/11 02:52 PM
01/25/11 02:52 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
as far as the ford junk comment there is nothing in it thats ford , dart block callies crank gas ported pistons and so on. car went 9.50s na and 5.70s on spray. i think it had a 4.100 stroke and a 4.155 bore
i think.6.200 on rod length.
