Re: 430" small block build
[Re: DJVCuda]
#912883
07/24/12 04:30 PM
07/24/12 04:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
ok - i was not sure what engine you were referring to.
I'll race ya - I got a head start, but you work quicker.
Yeah this is the engine in the Rampage... maybe I should have worked slower and I wouldnt be where I am.. should have looked the carb over... oh well... its only money... spend it like you have it...lol
[Re: BPE]
#912887
07/25/12 12:06 AM
07/25/12 12:06 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
How about some flow numbers on all 3 heads? And don't show us some gay graph, we just want to see the numbers.
Rod
That's a great idea,especially since you are changing the whole combination. Hard to tell what changes are resulting in the increases
Keith
[Re: Dunnuck Racing]
#912888
07/25/12 12:26 AM
07/25/12 12:26 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
actually if you have the gay graph post that too...im a visual person...lol...
cheapst..
actually i just read that and it sounds terrible.. i like to see graphs cause they eliminate correction factors and show a decent corrilation to the power graph after dyno-ing..
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: BPE]
#912889
07/25/12 08:40 AM
07/25/12 08:40 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Rod
gay graph as requested
please keep in mind this was all done on the bench at Fonses - it seems to be a little stingy from the advertised numbers, but since they were all done on the same bench I can get a good idea on how things look side by side.
exhaust
intake
[Re: emarine01]
#912898
07/25/12 10:14 PM
07/25/12 10:14 PM
DJVCuda
Atco NJ
Is the super vic ported? That pup is makin some power with conservative flow #s and cam
I gasket matched the intake, and also opened up the flange since it had that goofy overlap into it.
All the numbers were low - I'm not sure what caused that but they were all consistently low. The flow sheet from the MCH's add another 10-15 cfm in there and that is from his bench - I believe the test numbers were at 24" on the bench at the shop, but cant confirm that right now. but we did go into this knowing the numbers were low. I figure that since they are all from the same bench you can get a gauge as to how each stacks up against the other under the same conditions.
we had fun today finding hp - started out at 580@ 6500 - was way lean - needed to jet up ( was at 82 & 86 ) and timing was at 30 ( where the other 2 heads liked it AFR was in the high 13's and low 14's - -
next pull had jetted up to 84 & 88 - made 609 @ 6500 - still was lean - about 13.8:1 - gettin there!
Last run of the day was 34 degrees timing and 88's and 90's - thats when we hit 12.5 afr and 627 @6500
[Re: MR_P_BODY]
#912901
07/25/12 11:29 PM
07/25/12 11:29 PM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
108 LSA + 4
288/292 @ .020" Duration 258/262 @ .050" Duration 181/185 @ .200" Duration .426"/.430" Lobe lift .639"/.645" Advertised Lift with 1.5:1 rockers
My cam is similar but with a couple differences.. mine is 105 lsa installed at 105(didnt want the added torque with advancing it to increase the stall point) the lift is the same but I have a few more degrees on the exhaust side... same on the intake... with basically the same compression.... I know your gonna have more torque due to the stroke over my set up
similar to my cam too 254/262@050 .200 179 /184 cam lift 430/420 on 107 with 11.2 comp pulls like train with the indys , people over cam there engines some times these size cams are great street/strip cam well done with the build with great info and graphs ,you will love going down the strip with that combo
