426 hemi accessories question #912456
01/24/11 03:16 AM
01/24/11 03:16 AM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Ok, I am new to Hemi's and I am building one from scratch. Will big block accessory brackest fit on a hemi? or are they hemi specific? I have seen where people have used 440 crank pulleys but not much about the rest of the accessories. Does someone make a serpentine belt swap that is not a billet aluminum and looks more original with just a pulley swap? Thanks Tim
Re: 426 hemi accessories question [Re: astjp2] #912457
01/24/11 09:35 PM
01/24/11 09:35 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
BTT
Anyone?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 426 hemi accessories question [Re: astjp2] #912458
01/24/11 10:38 PM
01/24/11 10:38 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: 426 hemi accessories question [Re: astjp2] #912459
01/24/11 11:30 PM
01/24/11 11:30 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Some of you questions depend on what parts you are using and how it is equipped.
The factory Hemi balancer is much thicker than normal big blocks and makes a special lower pulley necessary.
Add power steering and another variable.
If you use the new crate motor style balancer, standard big block pulleys will work.
Special brackets for the power steering, are not Hemi specific but still hard to find.
Alternator can use normal with Hemi brackets (got mine from mancini), water pump also uses normal non A/C pump with pulley diameter to match the lower one you use.
Re: 426 hemi accessories question [Re: sthemi] #912460
01/25/11 05:33 AM
01/25/11 05:33 AM
QLD Australia
Keith Black® Offline
QLD Australia
There's nothing available that isn't either "bling" or cumbersome (just my opinion).
I'm presently having a custom CNC setup make that integrates the timing cover with accessory mountings for mini-p/s pump (remote reservoir), mini-hi amp alternator, mini-a/c comp. I'm using a Meziere electric r/f waterpump so no drive for the water pump. The rest will run on tensioners and serpentine system. It will also mount an F2-ProCharger (reverse drive) with gilmer belt.
The system will have everything in very tight to the engine and all below the level of the water pump. Big task but the designer is digitising the engine compartment now and designing everything up using CAD software, we will then CNC out the brackets. Should look good. The idea is to make it look as OEM (haha) as possible.
will post pics when done.
Darren Beale
Keith Black Racing Engines®
Re: 426 hemi accessories question [Re: Keith Black®] #912461
04/07/11 04:49 PM
04/07/11 04:49 PM
Utah and Alaska
astjp2 Offline OP
astjp2  Offline OP
Utah and Alaska
Did you ever get any progress on your project? Tim
