Page 1 of 3 1 2 3
Clanking sound and Vibration in the steering wheel #912401
01/24/11 01:57 AM
01/24/11 01:57 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i have a 1968 dodge coronet, was a 318, with p/s, is now 440 without ps, i took off the ps and used the one piece adapter, i also changed out the column shift to a floor shift column, the front end was rebuilt a couple of years ago , i found out the guy did not replace the strut bar bushings, i was told this may be the problem, when i am going down the road, i can feel a bumping type of vibration in the steering wheel, and when i brake, it is kinda of scaring, i went on the highway today, when i come up to red light and hit the brakes,
the steering wheel felt like a fair ride, it was vibrating and i could hear a clanking type sound and bad vibration and it felt as thought the whole front-end was falling out of the car, the brakes have also been redone, i did use a used steering box when i changed from the p/s to the manual, can some give me some direction, i know it will have to go to the front end shop, i was just trying to narrow the problem down so i know what i will be dealing with,
thanks
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912402
01/24/11 08:54 AM
01/24/11 08:54 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Just wondering if the dr.side manifold is touching the steering shaft . It would prolly depend on what manifolds u are using . Your description of problem sounds like the engine is touching somewhere. take another look around the side of the block , manifold , basepan etc. etc .
Re: Clanking sound and Vibration in the steering wheel [Re: mopar_man] #912403
01/24/11 09:45 AM
01/24/11 09:45 AM
Sandy, OR
DART67GT Offline
DART67GT  Offline
Sandy, OR
That's what my Dart did befort the front end rebuild. I think it was a bad ball joint.
1967 Dodge Dart GT 3.23 sure grip 8.75/727/360 .020 over w/edelbrock heads 2000 Dodge Ram 2500 Quad Cab CTD
Re: Clanking sound and Vibration in the steering wheel [Re: mopar_man] #912404
01/25/11 01:44 AM
01/25/11 01:44 AM
Brandon, Ms
Brandon, Ms
i am running headers and the steering shaft is very close, very close
i post the pic, if it is rubbing , why is it so bad when i brake?
i when out and it does look like the steering shaft is hitting the headers, i guess i can bend the headers to the get the clearence?
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912405
01/25/11 01:44 AM
01/25/11 01:44 AM
Brandon, Ms
Brandon, Ms
another
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912406
01/25/11 02:08 AM
01/25/11 02:08 AM
Brandon, Ms
Brandon, Ms
i changed from column auto shift to floor shift column and i think that is my problem, the floor shift column extends alittle further with the tube from the firewall, i guess i will try to heat up the header and do a little dent in the header
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912407
01/25/11 11:33 AM
01/25/11 11:33 AM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
HI Looking at your pictures i can tell you that the steering column shaft is not a factory piece . looks like someone made a homemade steering shaft coupler . that is probable part of the reason it is noisy. Also the headers would not even hit if it were factory setup on the column. Shoot another picture of the whole steering shaft down to the box so we can see for sure what is going on .
1969 Dodge Charger 1969 Dodge Superbee
Re: Clanking sound and Vibration in the steering wheel [Re: cjs69mope] #912408
01/25/11 01:01 PM
01/25/11 01:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is that mess ? Plus the header is way to close to the column and it's going to melt that plastic bushing.
Re: Clanking sound and Vibration in the steering wheel [Re: JohnRR] #912409
01/25/11 02:23 PM
01/25/11 02:23 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
That's a C body or 73 B body power steering coupler with the rag joint removed and just bolted together.
Re: Clanking sound and Vibration in the steering wheel [Re: 440newport] #912410
01/25/11 04:27 PM
01/25/11 04:27 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
don't bash the pipes. simply remove a couple of inches of the outer cover to the column.
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912411
01/25/11 07:01 PM
01/25/11 07:01 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
you can clearly see on the header that it is hitting the steering shaft. U need a coupler as the steering box and column is not always in alignment.
Re: Clanking sound and Vibration in the steering wheel [Re: mopar_man] #912412
01/25/11 07:08 PM
01/25/11 07:08 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
What?
Re: Clanking sound and Vibration in the steering wheel [Re: cjs69mope] #912413
01/25/11 09:38 PM
01/25/11 09:38 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
What?
HUH????
Re: Clanking sound and Vibration in the steering wheel [Re: mopar_man] #912414
01/25/11 09:43 PM
01/25/11 09:43 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
That looks scary.
Scott
1969 Super Bee, 383/4 speed
Re: Clanking sound and Vibration in the steering wheel [Re: StukaJU87] #912415
01/25/11 09:51 PM
01/25/11 09:51 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
That looks scary.
I like the nail in it too....
Re: Clanking sound and Vibration in the steering wheel [Re: StukaJU87] #912416
01/25/11 09:52 PM
01/25/11 09:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That looks scary.
For sure, just 2 nuts holding it togeather? Something is mismatched and missing like what was said above.
Got to be careful swapping parts epecially something like the steering.
Re: Clanking sound and Vibration in the steering wheel [Re: Challenger 1] #912417
01/25/11 09:59 PM
01/25/11 09:59 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Dude,do yourself a big favor,remove that hacked steering column from the car,and do not drive the car again,until you put the correct steering column,and coupler in the car. You could hurt or even kill yourself,or someone else. The $100 it would cost to put the correct parts in the car,will be a small investment,compared to the damage you could cause driving the car like that. If you have B body headders on the car,they should be designed to clear the factory steering column. If not,then I recommend you change them to headders designed for your application,from a reputable headder manufacturer. Never modify a steering column to clear the headders on a b body,when proper fitting headders are readily available.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Clanking sound and Vibration in the steering wheel [Re: cjs69mope] #912418
01/26/11 12:16 AM
01/26/11 12:16 AM
Brandon, Ms
Brandon, Ms
i guess i am to blame for this stupid set up, i bought a console and steering column from a guy, i thought was b body, turns out to be a 66'c body, he told me to just take out the rag joint and it wld work,
i really did not think this good idea, so this is my mess up, i have the old steering column, i guess i can grind off the column shifter and do some body work on the column housing and put the original back in, i have included some pics of my red-neck hack job,
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912419
01/26/11 12:18 AM
01/26/11 12:18 AM
Brandon, Ms
Brandon, Ms
another pic
Re: Clanking sound and Vibration in the steering wheel [Re: cornet684me] #912420
01/26/11 09:26 AM
01/26/11 09:26 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Not to be a critic , I just want to help . If it was my car and believe me I have had my share of Mopars.
First, fix your steering With correct column and rag joint.
If you have an accident and your car is impounded for an inspection ,I'm willing to bet your insurance is out the window .
Second, get rid of those rubbish headers, they are only a nuisance and unless you are an all out racer that needs that little bit of power they give you take them off and put on a set of HP manifolds. Then you will have a bit of satisfaction. What do anyone want headers on the street for ????? You can't go racing and like i said unless its a race car dump them .
Page 1 of 3 1 2 3
